Question about SMC WIRELESS-G SMCWPICG 802.11G EZCONNECT PCI WIRELESS ADAPTER
SMC7901BRA Modem + Router Cannot connect
When i first got this together with a Linksys wireless-G broadband router with 4port switch, it worked fine until i moved my broadband connection to another line and another space within the house.
Now I can't get into broadband connection even if i plug in the LAN cable and do a direct dial from just the SMC router without using the Linksys. A technical guy said could be a prefix auto dial connection in this SMS. I have done a reset by pressing the reset button behind, off the modem, restart my laptop but still can't connect.
Anyhow can help me with the auto dial configuration? pls email to 250488@gmail.com, if you have any answer
  • 2 more comments
  • mycarmen Oct 18, 2008
    some typo error above...
    "predix auto dial connection in this SMC"
    "Anyone can help me..."
    thanks Steve but was thinking not to use Linksys anymore since I am not using VOIP (purchased the Linksys for VOIP usage plan earlier)
    The SMC7901BRA ADSL barricade come with built in router which I can use by itself right?
    So, i need help to reconfigure this SMC instead of Linksys.
    Thanks
    it seems it doesnt have anything for win vista. could this be the cause that it cant connect?
    when i did a test via msn messenger, ip etc allright except for DNS and Key Ports. Pls help!!
    whole day i cant connect...now using dial up...VERY SLOW!
    been inside smc but still cant resolve the connection. perhaps some setting weren't right. i have the print screen on (1) setup wizard (2) advance setting. In the (2) i noticed the ATM PVC have IP Address "down", for subnet mask, gateway, primary & secondary dns " - - -". pls help.
    Sergeant:
  • 306 Answers
The Linksys router can be communicated with by going to Start>Run>type 'http://192.168.1.1' and when the logon screen appears use 'linksys' for username and 'admin' for the password. There you can reset defaults, view status, configure all router functions, et al, including restore defaults. Pressing the little reset button has reset levels that vary with the amount of time it is pressed -basically discharging a capacitive charge. Remember that cable modems use DHCP whereas DSL uses PPPoE. ~Steve
Posted on Oct 18, 2008
  • Stephen Medley
    Stephen Medley Oct 18, 2008
    OK, then here is the manual for a similar SMC barricade. IP settings for each manufacturer use the same config addresses and gateways so peruse this:
    http://www.smc.com/files/AS/MN_SMC7904WB...
  • Stephen Medley
    Domain Name Server (DNS) is what you need to resolve the ip address and the ports are the actual connections through which all communications are made possible. The Internet connection is impossible without those but they are not the problem -only the symptoms. If you see what the ip address actually is it probably is a number that starts with 169 like 169.xxx.xx.x which means that Windows cannot connect and so it just makes up an address. Sounds silly but Windows has to put something there so it just throws out the 169 domain. But you probably don't care about that so you need to do this:
    Go to Start>Run then type http://192.168.2.1, enter the password 'smcadmin' and you should be in the router configuration. This is all in Chapter 4. If you connect to the router then the next step is the Internet. I do not know how much you know so try that and read Chapter 4 so I don't have to repeat all of the words there. I am happy to help if you try that first. OK? ~Steve
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
I restarted my linksys broadband wireless g router and now my internet is down but i can still get online with the modem how can i get my internet up and running on my router?
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | Linksys Wireless-G Broadband Router
Cannot get a network connection using my linksys modelWRT54G2 WIRELESS ROUTER
Oct 03, 2010 | Cisco Linksys WirelessG Broadband Router...
No connection
Are you trying to set up router ?
Jun 26, 2010 | Linksys Wireless-G Broadband Router
Need software for linksys wrt54g wireless g broadband router
  • goto linksys.com and search for the modem number of the router, and search for the frimware
Aug 11, 2009 | Linksys Wireless-G Broadband Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
580 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
