Question about Acer 91.63X07.001 Keyboard
Acer LCD Monitor AL 1917W A
No power to the monitor
can you tell me how to take off the back
  • phchocs Oct 18, 2008
    ok that i understand, can you tell me how to take off the back cover as i cannot see how
  • 97 Answers
Check out the power cable for any damage.
There may be chance of damage of data cable, and because of that there may be no display in ur monitor too.
If all fails, then the power unit inside ur monitor may be blown.
Posted on Oct 18, 2008
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
Acer LCD AL 1706 A monitor will not come on
The problem can be bad capacitors in the power supply, look for bad caps with bulging tops or seal, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further. To have it repiared by the repair shop will not be practical, est $60~70 repair bill.
Mar 11, 2010 | Computers & Internet
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Images are too long horizionaly and short in height on this ACER AL 2016 WB monitor. Can it be adjusted?. Windows XP.
Have a look on the Monitor setup disk.
Somewhere on that disk you will find an instruction manual, this will tell you how to adjust your screen...
Jun 28, 2009 | Acer AL2016W 20" LCD Monitor
Acer AL 1917W- Same Problem
use the display /settings control to change the monitor resolution to 1440 x 900.
Please post here with positive or negative results to this as there are other factors which will take more explaining.
Nov 24, 2008 | Acer Aspire™ T180 PC Desktop
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Acer 91.63X07.001 Keyboard Logo
250 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
