Question about Axsion AXN6070 Portable DVD Player
Plastic thingee The plastic thingee that holds the dvd in my portable dvd player has broken. Can it be fixed?
  • Violist Mar 26, 2009
    I have a Axion 6070 and need to replace the black broken part the dvd locks onto when playing. Anyone no where I can get this part?
                                       Sincerely, George
    g43abdurrahman@sbcglobal.net
    President:
  • 3,130 Answers
Are you talking about the spindle turntabe that the disc sits on? or the clamper on the lid part?? Eather or Im sorry to say probably wont be worth fixing if you take it in to a shop or send it to their main depot for service. Unless you can contact the company and get the parts your self so you can take apart the player and replace the parts.. Good Luck
Posted on Jun 07, 2006
The spring in the lid of my insignia portable dvd player came out,how do i put back in?
It's likely it was fixed by a piece of plastic that has snapped off. If you can't find the piece of plastic you might have to improvise a bit, or look around for a new part.
Aug 04, 2016 | Insignia Televison & Video
The plastic hinge is broken. can it be fixed?
John, Venturer KLV39150 15" Under Cabinet LCD TV with Built-In DVD Player & Radio parts do not seem available(discontinued item)
Try 2 part epoxy and use a plastic backer to rejoin broken plastic, if possible.
press the helpful button and follow me on fixya for more tips
Feb 09, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
The white piece of plastic attached to the rail so it can move the eye ball reading back and ford is broken. I want to know where can i buy that part? thanks
This is something you'd have to contact the manufacturer for,
Though in all honesty it would be cheaper to just buy another portable player.
May 19, 2011 | Cyberhome CH-LDV 700B Portable DVD Player
I have a Sanyo DWM-400 it is a year old Rarely used... now allof a sudden it makes a strange grinding type noise and does not load movie... What is wrong and how do I fix it???
Might have a loose or broken plastic parts or a spinning motor is missing the gears of the machine device.Tries take the device hold it tight lift it over ur head shakes it a few times.That the easiest way to fixed grinding noises.
Mar 16, 2011 | Sanyo DWM400 DVD Player
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
Dvd player movie never loads
The lens on the DVD player might be dirty. Try taking a q-tip and soak it in rubbing alcohol. Next, open the cover and look for the laser lens. This is usually a clear white plastic circle looking piece. Take the q-tip and  clean the top of the laser lens but don't rub to hard. Let it dry for 10 minutes and see if the DVD will play. If not, then your DVD player is broken and needs to be serviced.
May 02, 2009 | Polaroid Portable DVD Player PDM-0822BD
Mintek 1810 stopped working, even after new cable.
Sound like you have experienced a component failure in the power supply. This might be repairable. You must open the dvd player by turning it over so the top is down and remove all the screws from the bottom. You must look under the feet and any rubber dimples to make sure you have not missed any hidden screws. You then must use a plastic pry bar or plastic putty knife (small) slip it into the area of the volume control and move it up and down slowly to carefully unlock the plastic locks hold the case together. One apart follow the a/c input circuit to the power supply portion of the pc board and use a digital multimeter to check components. Look for bad capacitors and burnt resistors. try replacing any bad parts found and put the dvd player back together again and test to see if you fixed the problem. If not you must repeat the operation until you either fix the problem or find you cannot repair it. If you cannot repair the dvd player you should just buy a new one and not try to get it serviced. It will cost about the same and you will have a new player. I hope this information helps you with your problem.
Dec 31, 2008 | Mintek MDP-1810 Portable DVD Player
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
Need new car adapter for RCA portable DVD player DRC630N
mine broke when it was new. i opened the cig lighter end and found broken wire. soldered it on and taped up the missing chunk of plastic. worked ever since.
Jan 14, 2008 | RCA DRC629N Portable DVD Player
NEED REPAIRS ON DVD PLAYER
polaroid dvd pdm-0722 it playes but no picture if you push the button near the screen it will come on for a second but the picture is also upside down can you help thanks this player is not used that much no kids thanks
e-mail is corv1990@eatel.net
Sep 02, 2007 | Polaroid PDM-0824 Portable DVD Player
Axsion AXN6070 Portable DVD Player Logo
Top Axsion Televison & Video Experts
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
