Question about Brother HL-2070N Laser Printer
HL-2070N paper LEd flashing
I've been on Brother site and chat rooms but with no luck. Printer worked faultlessly for 18 months then this problem merged after its fiorst paper jam several days ago.
I cleared the paper through the rear door and the flashing paper led came on agetr that. I've even opened it up but can't see a paper jam. I've rebooted et al
  • 2 more comments
  • goodkid21 Oct 20, 2008
    I have the same issue. No problems for a year, then one jam, now it flashes "paper" and won't work. It sounds like it is working on it, then just stops without feeding any paper. No jam, rebooted, reset, etc, still won't work.
  • ian5456 Oct 21, 2008
    Go to the top of the class CheckItRight.
    I think it must have come away when i pulled out the paper.
    Thank you,
  • Anonymous Oct 21, 2008
    I have the same problem. For a while when I took out the toner cartridge & shook it back & forth & renistalled, it would print for a few pages and then stop again. I tried the sugested solutions - cleaning the corona wire and checking the fuser (it was in the up position), but it still doesn't work. I just bought a new toner cartridge and installed it (even though the old one didn't seem empty). No help. I still flashes red and won't print. What do I do now?
  • leigha77 Mar 04, 2009
    I also had the same problem, no paper jam, sounds like it's going to work, but then...nothing. I cleaned the drum unit and my problem is also fixed.
See the brother support site. I cleaned the drum unit as suggested (last item), and the problem is fixed!
Posted on Oct 20, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
I bought compatible cartridge for my Brother
ok so its not a new cartridge there for 2 options remain.
1) it needs chipping back to 0
meaning its been refilled without being reset.. the little chip on the side..
2) its a dud sorry to be blunt but ppl can and will sell anything on ebay,,
hope this helps you
Sep 27, 2009 | Brother HL-2070N Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
2070N brother printer has flashing paper light
There is a paper jam inside your printer . Clear those paper , your problem will be solve.
Jan 10, 2009 | Brother HL-2040 Laser Printer
Brother laser printer HL 2070N
Hello rustyred, i tried to answer your live chat but my server or the fixya connection was causing issues. Trully sorry. can i still help? I am assuming you upgraded to vista from xp and you are missing the above options, might i suggest visiting brother web site and seeing if they have an updated driver for your printer compatable with windows vista, this may give you the options you want.
Mar 12, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N
According to the brother site, that means that the printer needs servicing. I talked to a local service center and they recommended chucking the machine--any repair is likely to cost almost as much as a new printer.
It's pretty disappointing.
Feb 25, 2008 | Brother HL-2070N Laser Printer
Laser printer HL 2070N
This may be in the Drum unit, DR-350. Something could be blocking the scanner so remove the entire drum assembly and check. Also a bad connection with the drum unit. If that is not it you may have a high voltage problem. I would first pull out the drum and look for anything like a piece of paper inside with my flash light. Since it is less than 3 months old, I would take it back for warranty because if it is the drum or another problem you should not have to pay for it! http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
587 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
