Question about Indesit W 123 Front Load Washer
Where is the agitator in a Indesit WG1385
Dear all, Where do I find this agitator in my Indesit WG1385 with a serial No. 506123246? My machine is not moving back and forward neither does the spin work. I can hear the same noise as the drum moving back and forward but it does not move. I thought it was the belt and I changed but still the same problem. Selecting the cicle I can hear evrything working, water does goes in etc,etc. Could this be the electrical motor not catching the signal from a selenoid??? Many thanks W. Lima
  • 641 Answers
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Posted on Jun 07, 2006
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Its spinning but the water is not draining away and the clothes are still wringing wet
This usually indicated a problem with the pump. There is a belt which turns the agitator, spins the drum, and turns the pump, which is what removes the water. Since the agitator works and the drum spins, the pump is probably faulty.
Aug 02, 2013 | Indesit W 123 Front Load Washer
My Indesit washing maching WG 1234 T, just keeps filling up and will not start its wash cycle.
Usually, when water fills up to a desired level, for example: choosing a small, medium, or large load. The floating switch will trigger a signal to turn on the motor to turn to start the agitation. In this case, the floating switch is bad or the floating mechanism is not working. Therefore the machine didn't do anything. It needs to access to inside the back panel to check it out. Cheers.
Aug 13, 2010 | Indesit Washing Machines
Indesit wg1185w wont wash
Hi, I think you will find that the heating cycle has failed! Does the water heat up? If not check the heater and the thermostat if you have one. No heat No wash cycle..!
Get back to me......
Jan 02, 2009 | Indesit WA 115 Front Load Washer
Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Aug 26, 2007 | Indesit W 123 Front Load Washer
Control switch turns 360 degrees
your module has blown and im afraid this fault is not worth fixing due to the price of the board you may b able 2 get a second hand 1 but make sure it is a good 1 with a small g/tee rough price £50 good luck the module is mounted at the back of the machine at the bottom on the left hand side 2 screws hold it in place
Aug 17, 2007 | Indesit W 123 Front Load Washer
Machine does not move back and forward
it proberly the carbon brushes in the moter get someone who knows what their doing to replace them easy job to do.cost £10
Jun 07, 2006 | Indesit W 123 Front Load Washer
Machine does Agitate
Indesit W 123 Front Load Washer Logo
120 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
