Question about Electronics - Others
Usb flash drive corrupted
My usb flash drive(8gb) can't detect by the computer and i don't know what happened. The file system of my usb became unknown and the capacity turned 0 bytes, the used space became 0 bytes, the free space became 0 bytes. I allready tried to used the properties>tool>error-checking but nothing happened. pls help me to recover my usb.
  • 1 more comment
  • noel Jul 29, 2013
    my usb 8gb toshiba transmemory turns to 4.00mb!!! how can i recover the capacity what should i do
  • noel Jul 29, 2013
    plsss need help
  • noel Jul 29, 2013
    i need to recover that
  • 72 Answers
Try other usb port, or other computer, if still have problem, download a usb recovery software, one I used before is Asoftech Data Recovery, you can follow this guide for usb recovery
usb file recovery guide
Posted on Mar 08, 2013
  • 1,447 Answers
Have you tried reformatting it? please be advised that you will lose your file if you reformat it. but that could help resolve your issue.
Hope this helps.
Posted on Oct 18, 2008
8gb usb drive shows 8mb raw
Want to format RAW flash drive into FAT32 without data loss?
Ok! You come to right place since I did have ever encountered the similar RAW drive problems and learned how to cope with such data loss troubles.
Honestly, while your flash drive was detected as RAW file system, though the PC was always asking you to format, your flash drive was not really corrupted and your drive files were still stored inside this drive well.
All you are supposed to do is to download RAW file system recovery software to take the inaccessible original files back and convert flash drive from RAW to NTFS safely.
Hope my experiences could give you useful clues.
Jan 02, 2014 | Electronics - Others
My Kingston DataTraveler G3 8GB USB 2.0 USB Flash Drive (White/Yellow)'s data all got corrupted, and i a cannot do anything [copying, pasting, renaming, moving, etc.] with the corrupted files/data
Get data back is a file recovery program for flash drives, it may work for this, but if the files are corrupt you would then be recovering corrupt files.
Apr 20, 2013 | Computers & Internet
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that...
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I bought a Kingston 8gb flash drive and then it became RAW
you might have a virus on it. scan it with a virus software program. also try another usb port. some times the 2.0 ports don't work on the 1.0 ports.
hope this helps
Apr 30, 2010 | Electronics - Others
I have an 8gb flash drive, it just so happen that
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
Feb 16, 2010 | Electronics - Others
I'm a tech IDIOT - I bought an 8GB flash drive to back up ''my documents'', but don't know how to DO it. I've put the flash drive into an available USB port...
Please follow the simple steps to copy the data from your computer.
1. Plug in the flash drive to the USB port available.
2. Wait for a while til the system detects the drive and it will show the detection details on the extreme right side of the task bar.
3. Once the computer has detected the USB/Flash drive you can do a double click on the MY COMPUTER icon on the desktop where it will show you th external drive as a Removable drive. Once confirmed you can close the page.
4. Then you need to go inside My documents by doing a double click on it.
5. Select all the documents by either doing a CTRL+ A or you can select the documents one by one by pressing CTRL and with the mouse just single click on a document.
6. Then after you have higlighted the articles to be moved please do a right click with the help of mouse cursor, where it will give you a option SEND TO and then you will have the option of Removable drive over there.
7. Just select the removable drive and all the data will be copied with in the next few mins.
Your system will tell you the time it wil take in order to send the complete data.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 06, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to fix cannot read usb
sometimes this is a voltage issue. try plugging directly into the computer, and not into a USB hub.
Oct 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I just bought a Sandisk Cruzer Micro, 8GB. My problem is that I'm rather computer illiterate. Can you tell me how to use this thing? Where to plug it in , etc. What do I do after its plugged in. I have...
1. Find a USB port on your computer usually it has a 3 pronged logo on it
2. plug it in, it will only fit in one way its a rectangle.
3. your computer if running on an operating system made after windows 98 will auto detect these jump or thumb drives.
4. you can browse to this new memory using my computer on a PC or by using finder on a MAC.
to copy files the easiest way i know to do so on both PCs and MACs is to select the files off of the source and drag and drop (or copy and paste them) to your new 8GB drive.
5. once you can see the files on the USB drive open them so you know the file is there and not a short cut.
You should strongly consider buying a second back up like an external had drive. you should have 2 back-ups of critical files.
-good luck-
Feb 19, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Electronics - Others Logo
580 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
