Question about Indesit W 123 Front Load Washer
Machine does Agitate
Dear all; I have a Indesit washing machine model WG1385, Serial No. 506123246.. Once stwiched on it sounds like the drum is turning but it is not. I can hear clicks,clicks but it does not turn around, there is not spin either, apart from that everything is fine. All the programs are functioning OK. The water cold and hot goes in fine,then the pump released the water fine. I changed the belt. Could this sound to you like the electrical motor has gone? Many thanks for your patience. Many Regards. W. Lima
  • 641 Answers
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Posted on Jun 07, 2006
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
I have an Indesit 1400 model WIXL143, washing machine, which is about 3 and a bit years old. It sounds like a tank when its on spin, and makes a grinding noise also. Its also making the washing dirty...
yes probably order them from parts place or eBay but big job to do are you up to it best get quote from indesit probably cheaper new washer
Oct 25, 2017 | Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Feb 23, 2007 | Indesit W 123 Front Load Washer
Where is the agitator in a Indesit WG1385
Jun 07, 2006 | Indesit W 123 Front Load Washer
Machine does not move back and forward
it proberly the carbon brushes in the moter get someone who knows what their doing to replace them easy job to do.cost £10
Indesit W 123 Front Load Washer Logo
126 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
