Question about Acer TravelMate 2413LCi Notebook
Drivers for my cd/rom - Acer TravelMate 2413LCi Notebook
  • Anonymous Feb 03, 2009
    i have a problem with drivers for acer travelmate 2413LCi please help me
    Sergeant:
    Champion:
  • 214 Answers
Download from acer.com
Posted on Oct 18, 2008
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
I can not get my Cd Rom to read a disk
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 26, 2010 | Acer (91.47A37.001) CD-ROM Drive
Cd drive wont open
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
My cd-rom can't read CD-R??!
Nov 25, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Every time I put Any kind of CD the driver cd rom
first uninstall the drivers of CD-ROM and then again install the drivers you will see that it will play your CD.
If it doesn't play then check your CD-ROM jumper settings remove the pin and set it to slave mode.
Oct 08, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
I need to download a driver for matshita cd-rom cr-176
The driver you are looking for might be found here, http://www.cdrom-drivers.com/drivers/0/104.htm
Dec 30, 2007 | Panasonic CR-176-D (CR176D) 24x CD-ROM...
Cd driver
CD-ROM driver help CD-ROM drivers, helping you load your CD-ROM drivers on PC computers, listing what to have in the autoexec.bat / config.sys, listing different drivers .
Computer CD-ROM drive help and technical information. Complete technical help and support dealing with computer CD-ROM drives.
Good Luck if this dont do it for ya, re-install your computer back to the factory setting.
Please dont for get to Vote, Thank You.
Dec 26, 2007 | Acer Aspire 5100-5033 Notebook
Cd rom
Where can I get the driver for my CD-ROM?
Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
Dont for get to Vote / Merry Christmas.......Good Luck!
Dec 06, 2007 | Computers & Internet
Acer TravelMate 2413LCi Notebook Logo
486 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
