Question about JVC AV-28GT1B 28" TV
Jvc av-28gt1sjf anyone know if there is a reset code i can press into my jvc av-28gt1sjf.i cannot get av with my remote or by pressing the normal channel buttons.my remote works perfectly fine and so does my television apart from not getting av
    President:
  • 3,130 Answers
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Posted on Jun 07, 2006
Trying to program Insignia remote to JVC TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Codes for JVC TV are: 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Aug 19, 2012 | Insignia New Original KK-Y284B Remote...
How to connect xbox to jvc av-28gt1sjf
I assume that since you do not have remote you cannot choose another AV channel on your TV. If so you can use the RF input using a RF converter to AUDIO /VIDEO or if not the sky input must be shared through a VCR/DVD or multimedia/DTS amplifier
Nov 30, 2011 | JVC AV-28GT1B 28" TV
Hi lt40fh jvc how do i get the channel locks off please
Hello
If you forget the Lock Code, a new code may be set using the steps listed below.
After a power interruption you must reset the Lock Code
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press the MENU button
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
The first digit will be highlighted
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Continue to follow these directions for all four numbers
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
Dec 28, 2010 | JVC AV-27230 27" TV
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
I need to get code for tv
Hello
Three Digit universal remote codes for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Four Digit universal remote code for JVC are:-
Direct Code Entry
Nov 30, 2010 | JVC AV-27530 27" TV
What is the universal remote code for JVC AV27D302
Hello
Four Digit Universal remote codes for JVC are:-
0060 _0026_ 0197_ 0069_ 0247_ 0923_ 0012_ 0065_ 0067_ 0141_0048
Three digit Universal Remote Code for JVC are:-
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 20, 2010 | JVC AV-27D302 27" TV
Channel number on screen
Just press the Display button on the remote.
Feb 15, 2009 | JVC AV-27530 27" TV
RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Oct 11, 2008 | Radio Shack (15-2147) Remote Control
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Sep 09, 2007 | JVC AV-27020 TV
Cant get av channel
Is it that the remote dosent work?? Does it switch the tx on and off or does the volume change from the remote. NO?? then your remote is broken . Take out the batterys and replace them and see if that helps. Remote works?? Ok if the remote does work but wont let you into function then your gonna have to contact JVC at proinfo@jvc.com Or look in your owners manual for a local branch as i see your from The UK. Good Luck and Im sorry i cant be of more assistance.
Jun 06, 2006 | JVC AV-28GT1B 28" TV
JVC AV-28GT1B 28" TV Logo
258 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
