Question about Panasonic NN-P794SF Microwave Oven
Electrical issues inherent in this model?
We've been buying (ahem...exchanging) this microwave at Costco repeatedly for replacements due to essentially the same thing. The first unit self-destructed one morning when pressing the Start button. It actually caused the lights in the house to dim. This unit also had a sticky door that required you to hold the door 'eject' button and then yank the door open.
Exchanged for Unit 2. This unit make chirping noises that sounded like electrical arcing when it was running. Random, periodic chirps. Not from the beeper or the rotating tray mechanism.
Exchanged for Unit 3: Again more arcing sounds when cycles run.
Exchanged for Unit 4: Vibrations from rear panel at times. This unit actually made the arcing noises while "off" with just the clock displaying. At that point I just unplugged it. I want to exchange it again, but the only other model Costco offers is the Panasonic with the stupid knob instead of number buttons. Costco will keep taking these stupid things back which is why I don't go to another store which will have an itty ***** return policy.
Anyone else have so much trouble with a microwave? It makes me want to go to the second-hand store and buy an OLD microwave. Those that were built to last more than a few months and to not burn your house down.
    New Friend:
I agree...the knob is so stupid. I spin a dial for volume in my car, not for the length of time I want to heat up my soup
Posted on Apr 09, 2013
  • dave Apr 09, 2013
    i agree...the knob is so stupid. I spin a dial for volume in my car, not for the length of time I want to heat up my soup
    Scholar:
  • 181 Answers
Its the problem of voltage the electriccurrent.call a electrician and get the electricity power checked of your place.the oven is getting required current so this problem is coming.
Posted on Nov 13, 2008
Everything works but just want start
It seems your have a general failure in the power control or switch failure on the unit. Since your unit has power, and things lite. it is more likely you have a control/switch problem,
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
Aug 05, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
My microwave oven timer works, the turntable turns, but it barely heats, so can't be used. It worked well till yesterday.. Any ideas what the problem could be? Its a 2006 model.
Sorry to read about your problem, I hope this helps you out. you can have one of the issues.
  1. Low line voltage.
  2. Magnetron with low emission.
  3. Faulty controller or set for wrong mode.
  4. Intermittent connections to magnetron filament or elsewhere.
  5. Faulty primary relay or triac or HV relay (not commonly used).
  6. Damaged protective VDR from filament to chassis (not commonly used).
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Goldstar MV-1501 Microwave Oven
Vent fan turns on if you open the door or if you turn on the light. Do I need a control panel?
no you can have many different issues, other than a control panel. and other than that i must give you this warning, and good luck
3 Thumbs - Helpful
Jan 04, 2011 | Whirlpool MH3184XP Microwave Oven
After using the oven, when I attempt to use the express function-it reports an error function #6
You have a keypad/control issue.
3 Thumbs - Helpful
Jan 04, 2011 | GE Advantium SCA2000B Microwave Oven
We were defrosting meat yesterday and the microwave powered off & has yet to come back on. Is there a fuse somewhere on it or maybe a reset button? We tried unplugging it & resetting the...
Their are fuses and other issues, that can cause your issue's
3 Thumbs - Helpful
Jan 03, 2011 | Magic Chef CMV1000B Microwave Oven
My sharp microwave oven model no: R-9H20 needs to be replaced with a new feather touch pannel. Is the spare part available in market. If so where can i buy it.
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount. 1
3 Thumbs - Helpful
Jan 02, 2011 | Sharp R-1480 Microwave Oven
Kenmore microwave model 721.80409400 is noisy while operating like a loud 60 cycle HUM or BUZZ otherwise works OK
you may have a magnetron issue, or these other issues
  1. Shorted HV diode, magnetron.
  2. Burnt carbonized food in or above oven chamber.
  3. Shorted winding in HV transformer.
  4. Frayed insulation on HV wiring.
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore 80402 Microwave Oven
What does the F9 display mean for a Kenmore Elite Microwave Model 72163769300?
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore 63792 Microwave Oven
What does an error code of F-9 mean on a Kenmore ultra wave microwave model 721?
Mar 22, 2010 | Kenmore 63792 Microwave Oven
UNIT POWERS OFF AND DISPLAYS "F-9"
an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician. Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
Aug 03, 2017 | Kenmore Microwave Ovens
Panasonic NN-P794SF Microwave Oven Logo
311 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
