Question about Epson Stylus C43SX InkJet Printer
My Epson Stylus C43SX does not print without the black ink
Whenever i try to print with my fonts all in dark blue, my printer does not print it because it says the black ink is empty
  • Anonymous Nov 30, 2008
    My epson DX4000 doesn't print if an ink is empty. I don't know why, but this is really annoying as the cartrige is kinda expensive too. [They add 2-3$ to the price monthly] And whenever you change an ink cause it's empty all of a sudden the other inks lose some "levels" too.
  • Anonymous Mar 26, 2014
    the printer will print but no blue ink willbe used
  • 353 Answers
I sympathise with your frustration - we all feel it. Epson printers, by design, will only work if all cartridges are present and correct. When you change a cartridge or carry out a head clean, the ink charging and head cleaning is carried out on all cartridges. So what you are experiencing is normal, I'm sorry to say.
My advice is to buy the cheapest compatible cartridges you can get - have a look at e-bay in particular. In the UK a set for the DX4000 would cost less than 6 UK pounds, including shipping. If you are prepared to buy several sets at once you can save a lot more.
Note for future reference that your query was in the C43SX section - make sure you post your queries in the right section, otherwise people who could help you may well not see it.
Posted on Feb 10, 2009
My epson stylus c43sx did not installed or not found
If you are just looking for a basic inkjet color printer for your term papers, or resumes, then this might work fine for you. This uses T038 ink cartridge for Black and White, and a T039 for colored.
However, if you are doing printing most of the time, you might want to invest in an ink-saving printer. This one, from my experiences, empties my cartridge so easily, especially the colored ink.
Other good feature of this printer is you can choose from five print modes. Draft, lets you print speedily and is useful if you just want too transfer some long notes from your screen to a paper. The print is quite thin like a dot matrix print and uses very little ink, but it is quite readable and clean.
Dec 04, 2009 | Epson Stylus C43SX InkJet Printer
Print out of my epson printer c43sx is blurred
Two things check the ink or go to the manufacture's website and download the latest driver.
Apr 08, 2009 | Epson Stylus C43SX InkJet Printer
Ink Supply Problem
No, the Epson Stylus C43SX design requires that both cartridges are present and working i.e. not empty. If you wish to always print from one cartridge e.g. black, you can refill the empty color cartridge with distilled water and reset it to full. For this you will need a chip resetter (very cheap - see e-bay for example). Do not run with a dry reset cartridge - you'll end up with a damaged print head.
Aug 15, 2008 | Epson Stylus C43SX InkJet Printer
Black 3e ink not printing
try to test the new cartridge;print a test page or try head cleaning in the printer maintenance software.
Apr 12, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx current ink levels not shown in the properties
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
Printer says no ink
I have a similar Printer. And similar problems crop up. Have tried cleaning the contact terminals in the cartridge slot? (You will notice a small PCB on the TO 38 Black ink cartridge) This terminal sends data to the Printer and then to the Status Monitor screen.If these contact terminals are dirty, or if your cartridge is not a Genuine Epson TO 38 cartridge but a generic alternate cartridge, then the PCB contact configuration will be different and so will send wrong data to the Printer Logic Processor. My suggestions are 1. Make sure yours is a Genuine Epson TO 38 cartridge 2. Clean the contacts in the Cartridge compartment. 99% your problem should be solved. Pravin Gupta, India guptapravin@hotmail.com
Jun 19, 2006 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
356 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
