Question about Compaq Presario R3000 Notebook
R4000 will not boot, I think HD is bad. Is there any online manual to show how to take apart to get HD out? Also are there updates to BIOS so that I can boot from USB [now only floppy, cd, HD or network]. Is there any way to run laptop without a HD, by using an external HD [these are cheaper and I have afew extra ones]. Thank you Steven
  • Steven Mettler
    Steven Mettler Oct 18, 2008
    usb option is not in bios version F.14 that is on laptop now. I am not sure if bios upgrade will add it in bios? That was what I was asking. Also, according to bios update, it is done under windows so I guess I'll need to buy a new HD first or is there another way? thank you Steven
  • Steven Mettler
    Steven Mettler Oct 20, 2008
    will not boot from CD. Compaq told me in online chat if HD goes it will not boot to anything, wouldn't tell me if bios update will correct or not, they didn't seam to know much. I called today to get a price on HD and they told me they wouldn't tell me a price unless I had serial number [as if there are millions of HDs for a laptop].
    Sergeant:
    Champion:
  • 331 Answers
Yes u can run a usb from the boot menu
u will have to configure the bios.........
u may have to make some changes to ur external hard disk
u will have to use some ones comp to do these aas urs is not working...................
i got this from the net and this should work
Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ | Alt: mkbt20.zip Put a bootable floppy disk in your A: drive or create one using Windows.
Download mkbt20.zip and unpack to to new temp folder you create.
Go to the temp folder.
Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:
mkbt -c a: bootsect.bin
The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
Format the flash drive in FAT or FAT16.
Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:
mkbt -x bootsect.bin Z:
"Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly.
Now you can [grin] "should" be able to copy the utils you need to the pen drive.
Posted on Oct 18, 2008
  • Varun Kumar
    Varun Kumar Oct 18, 2008
    ok then ur problem seems to be that ur bios does not support usb boot...
    what u could do is first get ur updates on a floppy which u will get
    and then if u could manage to get hold of a bootable Linux installation (On a CD) u could boot the linux and then update ur BIOS from linux
    tell me if that works.......
    bye
  • Varun Kumar
    Varun Kumar Oct 27, 2008
    i am telling u can
    boot atleast from a cd if the HD fails i have tried that ..
    and maybe ur hard disk did not fail it may just have been dislocated from its place ..
    did u try a person whos has experiece openin laptops...
Dell laptop no boot device available I turn it off then restart and everything boots up
Go to support.dell.com, enter your service tag and look for driver updates. The main ones you're interested in are BIOS updates and Chipset updates. Depending on the age, your CMOS battery could be going out and need to be replaced. They're only about $3 but you have to take the unit apart to replace it. Dell should have a manual that shows you how on the support site. Try the updates first.
Sep 04, 2014 | Dell Computers & Internet
New computer won't boot -
I had a similar problem with asus. 1) check online that the motherboard supports that cpu. Mine did not. I had to return it. 2) try the memory in different slots and combinations 3) try a different video card 4) check the CMOS clear jumper os properly set to disabled. Set it to enabled (power off first) 1 time to clear it. reset jumper back to disabled, and power on as usual. I'd suspect the motherboard needs to be flashed, but you obviously cannot flash it without it working... return it to point of purchase, or have them flash it and show you that it's working with your processor before you bring it back home.
Aug 26, 2007 | Computers & Internet
Persario r4000 won't read software cds
tada ! a compaq from the past. OMG runs XP right?
12 year old LT.
this topic is very complex.
first off no OS stated, opr. sys? XP
answering for XP. the dead OS.
No Optical drive label stated, vast models used and sold. for 12 years.
First off Ill say your XP drivers are bad, or the XP is infected as all are.
no photos presented of your Compaq install disks
so i can see then and read them with my eyes,
to know exactly what is there. wow.
if you cant read them in XP
that means XP is messed up or the drive is bad or the disk is bad.
so boot the disk using the BIOS.
ever use BIOS , it tells you how do that at every boot on the screen , like"hit F2 to enter bios setup)"
or some hot key, varies by year, mine is ESC.
if the disk boots and runs, Compaq, HP or Microsoft
then the DISK is ok and the PC is ok and the DVD drive is ok, leaving what, bad XP.
is XP fully updated to SP3?
XP has always had difficulty with optical drives.
not only that XP shut down support
so if you try to install MS drivers for this DVD drive how can it? XP is DEAD now.
ever go in to device manager and do search for missing devices, and be online doing that,
but wait , its now DEAD at MS this feature.
why not just get PC that has w7 on it
and end all this misery
$20 fix , buy a used PC that is not 12 old.
you want a PC nearer than year,2009 with a w7 COA sticker on the bottom. and win !
see cheap pc here far better....
http://www.pcdied.com/cheaper.html
Jul 05, 2017 | HP Compaq Presario R4000 Notebook
Acer aspire one note book problems start up won't let me reboot quick blue screen message tried everthing in :f8: options and won't let me in to safe mode
I have the same problem with my acer laptop 3680. It is stuck on the BIOS screen with "press f2" at the bottom. I can get into the menu by pressing f2 repeatedly as soon as I hit the power button, and was able to change the boot order to CD first, but it will not boot from the Windows CD even though the CD drive is flashing and I can hear the CD spinning - same as the hard drive - still get the BIOS screen. I took it completely apart, dusted with compressed air, replaced RAM (new), and still same f2 screen. I removed the hard drive and booted up and the BIOS screen did not appear, but it said "Drive not found". Therefore, I think I have a dead BIOS battery since the BIOS isn't present without the HD. I did not notice a battery when I had it apart and have read that it is soldered in and almost impossible to replace. I ordered another motherboard on eBay (search: motherboard 3680) for $89 BIN today and will post again with results hopefully next week.
Have you tried pressing ALT+F10 on boot? If lucky, that will get the recovery console and you'll lose all data. I was able to save everything from my HD by plugging it into my PC with a USB/IDE adaptor which can be bought for cheap online and in most computer stores.
Feb 25, 2010 | Acer Aspire 3680 Laptop
Bios not working
Disconnect the hdd and see if it shows a BIOS screen. I can't think of anything else it could be other than the BIOS if this doesn't work. A "Windows Update" should harm any hardware on your motherboard. It could only affect the hdd, read/write....
Jan 16, 2010 | Foxconn Computers & Internet
I have a problem with an Acer Aspire 6930, sometimes during startup ut shows a message that it cant find windows and shuts down. After trying again it powers on normally. But i wasnt able to find the...
If it is an older Laptop... it could just be the HD not spinning up correctly or not spinning up as fast as the PC is booting. There is a HD check to the BIOS in the first seconds of the Boot. BIOS doesnt see it... you get the fail.
A good test is after it fails... do a CTRL/ALT/DEL to restart the system... if it Boots then it was the HD not keeping up.
OPTION: Also check to see if the BIOS needs updated and this is a tricky opperation to do... make a mistake you loose your system. This could also help if the condition is common and a patch was created.
It doesnt hurt the to run it the way it is. The Drive lagging like that doesnt always mean the HD is bad. If it occours every single time I would worry. Buy a New HD to be safe and also the newer HD's will help 100% on the Speed of the system.
Jan 02, 2010 | Acer Aspire 6930-6455 Notebook PC
Can't boot 2nd OS system from partitioned HD.
go to add and remove software, deleted the last update from Microsoft. it should put you back to dual boot. try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
Jun 04, 2009 | AMD Athlon , 750 MHz Processor
Format HD fails on armada 1592DMT
The safe bet is to go into the bios and choose "load Bios defaults" then restart. If your HD fails on the format command, it is probably bad.
Mar 20, 2009 | Compaq Armada 1592DMT Notebook
KEYBOARD DRIVER FOR COMPAQ R4000
There is no driver from Compaq because it just uses a standard driver from the operating system.
Try removing the keyboard from the device manager.
Then restarting the computer.
Let me know what happens.
Feb 27, 2009 | HP Compaq Presario R4000 Notebook
Presario R4000 does not detect 2GB of memory
Hi PhotoTom,
I check you laptop specification and it really do support uptp 2 GB. So here I'm not sure your 1GB are both of them DDR 333Mhz ?? .If so what I really want you to test here is
1. 1 GB in one slot and turn it on (as you say you can boot wih it) after that move that 1 GB to the other slot and see.
2. try the same with the other 1GB and see that both work fine on both slot or not.
Incase both work fine on both slot then maybe problem with hardware what I want you to do after that is try to check your BIOS version and check on the website that they do have new BIOS version or not ?? Coz this can help incase problem are from BIOS.
Goodluck,takecare.
May 21, 2008 | HP Compaq Presario R4000 Notebook
Compaq Presario R3000 Notebook Logo
237 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
