Question about Kenwood KAC-9103D Car Audio Amplifier
LED is on, but no sound
I was wondering if you could give me a little more detail. I have a fuse and it's 40A, i don't know much, but I really don't want to pay someone to do it.
please help
trygod777@hotmail.com
    Novelist:
    Scholar:
  • 85 Answers
If the LED is on then that pretty much means that your remote wire is functioning properly but that does not always mean that the amp has power
The 40amp fuse connects to the main power wire that is run from the battery to the amp and must be connected at the battery end NO MORE THAN 18 INCHES from the battery but the closer you can put it to the terminal the better since this fuse protects you car from extreme damage or fire that can occur if the amp power wire should happen to short out.
TIPS:
Power wire from battery to amp needs to be at least the same size or bigger than recommended for the amp (the longer the wire the thicker it should be)
Always Run amp power wire through a rubber grommet to the engine compartment to avoid wire short that can be caused when car parts move and flex during driving
Run power wire on separate side of car away from RCA cables to avoid noise in the system
Posted on Nov 20, 2008
Lacks power, choke will not go full
some of you guys really ask bad questions, provide little details so don't be suprised if no one can give you a answer. i don;t know try draining the old stale fuel out and replenishing with fresh, check basic stuff like clogged air filter, or in line plugged fuel line. the thing needs fuel, air and spark to run in the proper amount, test the plug too for fouling and proper gap. but sound like its likely a fuel problem
Aug 13, 2014 | Garden
I have a 2003 mitsubishi lancer. Everytime I try to turn my key from the ignition to start my car my fuse 4 (40A) blows up I replaced it twice but the new fuse just keeps blowing up:/ what's going on?...
There is a major electrical fault that keeps blowing the fuse. The fuse protects that part of the electrical circuit, 40 amps is heavy electrical circuit, it it wasn't protected by a fuse it car could catch on fire.
You need to get an auto electrician or your Mitsubishi service center to locate the fault and repair.
If you had a wiring diagram for your car then you can trace the wiring from the 40A fuse to the various components to locate the wiring fault or component fault.
Dec 30, 2012 | Cars & Trucks
20A ACC/cig fuse, 40A fan fuse (AC) keeps blowing on 05 Sebring.
Disconnect the cigar lighter and see if the short goes away, I will bet it does.
Aug 09, 2012 | Chrysler Sebring Cars & Trucks
Can I replace a T 40A / 250v fuse with a 13A fuse for a tv ??? Or is really necessary to get the same one ??
Have never seen a 40A Fuse in a TV! Kindly look at the board and check whether there is any fuse rating written there. Put only the correct value and rating, as fuse is a safety device that 'suicides' to protect others!
Jul 30, 2012 | Televison & Video
Infinity gold radio seems to work but cant get any sound
It's really hard to answer a question such as this. There's barely enough information to reach any type of conclusion. What kind of Jeep? Cherokee? Grand Cherokee, Wrangler? Renegade? Liberty? I could just keep going. Maybe it's a Willys 1942? I really don't know. However, based on what little information you've provided I'll give a little answer. Fuse. How's that. No. Wait, if it's an infinity system it has a factory amp. If only I knew which year and model...Hmmm, Cherokee's and Grand Cherokees have them under the back seat. Does yours have a fuse in it? I don't know BECAUSE I DON'T KNOW WHAT YEAR AND MODEL IT IS.
Jul 23, 2011 | Jeep Cherokee Cars & Trucks
I have an LG 42PX3RVA. The screen went blank, but there is sound. I don't know it there was a "pop", because I was not at home when it happened. I have disconnected the power and checked all...
Test the fuses using a fuse tester, if you don't have one then use a flashlight and some wires,
connect the light in series with the fuse and the batteryfor the light if it turns on the fuse is good if not then it is blown and should be replaced.
Jun 29, 2011 | Televison & Video
Hi just wondering if there is a way to turn off the orange indicator light on my dell laptop that shows the touchpad is inactive. The light is really annoying (I want the touchpad to be inactive but not...
This is an incredibly simplistic fix but it might work for you purposes. I don't know of any way to
turn this light off but you might be able to cover it with just a little electrical tape.
May 06, 2011 | Dell Inspiron M5030 Laptop
The heater on my renault megan scenic wont work
hi everyone my wifes renault scenic fan switch that controls the speed of fan wont work so no heater ive checked the 40a fuse and its ok just wondering if any one knows why its suddenly stopped thanks
Dec 20, 2010 | Renault R5 Cars & Trucks
Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Jul 24, 2009 | Audio Players & Recorders
Heater stopped working today. Rear still working but not alot.
2005 Chrysler T&C Van. My front blower also stopped working overnight. Rear blower works fine. I swapped the 40A fuse in the underhood fuse box with the 40A fuse for the power seats since I don't have power seats. No help. I then swapped the front blower relay with the spare relay in the same box. No help. I'm wondering if there is a reset button for the blower and if so where it may be. Any hint or help with the blower would definiely be appreciated. Thanks
Jan 02, 2009 | 2005 Chrysler Town & Country
Kenwood KAC-9103D Car Audio Amplifier Logo
88 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
