Question about HP LaserJet 9500n Printer
Can't find what displayed error message means
I have a Laserjet 9500hdn that is displaying an error message. It reads "49.234A service error", any idea what the problem is?
  • 417 Answers
This is normally down to the information or data if you will that you have sent to the printer. Delete all in the print que and restart the printer.
If this doesn't work then tun the printer of and remove the additional memory. Turn on and tested again.
If still doesn't work then problem is with the printer formatter board the firmware is corrupted or the board is faulty either one is a hp repair or a second hand machine.
I do hope the first two help you
Thanks J
Posted on Jan 07, 2008
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
Hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
May 04, 2009 | HP LaserJet 4 plus Printer
DISPLAY READS: 80 SERVICE (01E4)
If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
Jun 16, 2008 | HP LaserJet 4 plus Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
Can't What displayed error message means
49 error normally means that the information sent to the printer is corrupted clear the print que shut down printer and restart. If problem still there then shutdown the printer then remove one of the additional memory turn back on if still same problem repeat removal of the next memory replacing the one you have just removed and so on. After you have done this and you are still getting the problem then it is 99% certain that the printer system firmware is corrupted or the formatter control board is faulty.
Thanks J
Jun 07, 2006 | HP LaserJet 9500n Printer
HP LaserJet 9500n Printer Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
