Question about Canon VIXIA HV30 DV Camcorder
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I want to edit video. My camera displays a 'HDV/DV' connection when plugged in, but my Mac does not recognize the camera. ?
  • 2 more comments
  • rickmitch Oct 18, 2008
    After much investigation, I found that I needed to be running iMovie, then plug in the camera. iMovie then recognizes the camera and can be operated from the iMovie controls and downloaded. Unlike my other camera, and most storage devices, the computer does not recognize the camera when you plug it in to the computer. The software that comes with the camera is only for still images and can not operate video files.
  • Anonymous Dec 22, 2008
    I've got the same problem. I'm trying to edit in Final Cut and my imac doesn't even recognize the HV30 when it's connected. WTF? I've had a similar problem with my Canon G7, it only works when iphoto is opened.
  • Anonymous Dec 31, 2008
    my mac doesnt detect my hv20 at all no matter what i do the wire is fine so either i have a defective firewire port or i just dont know whats going on
  • Anonymous Jan 15, 2009
    I have the same problem has anyone found a solution to this??
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Posted on Feb 20, 2010
  • oudinmelanie Nov 18, 2010
    Thanks for sharing this useful post.
    When you edit HDV/DV formats with adobe premiere, FCP or iMovie, you will find the HDV files are too large to eat up lots of CPU, so playing back these files are really choppy/jerky. In this case, you have to transcode HDV files to other video formats for better playing and editing.
    The program I recommend to convert HDV video files is Aunsoft Video Converter for Mac which is a professional in converting HDV files to MOV, AVI for perfectly editing and playing.
    http://www.aunsoft.com/video-converter-m...
  • 18 Answers
DO you have an external hard drive connected? sometimes that imposes on the connection....do you have a hdv compatible software program on the computer....and if you do...make sure the settings for input are correct
Posted on May 30, 2009
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
Mar 18, 2011 | Canon VIXIA HV30 DV Camcorder
Tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step1: Install and Launch Doremisoft AVCHD Converter for Mac
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 | Computers & Internet
(Canon HV-30) Firewire not responding any more with Final Cut Pro
SET YOU CAMERA TO FIREWIRE OUT, NOT AUTOMATIC!! <!-- from fixya rte -->
Jan 28, 2010 | Canon VIXIA HV30 DV Camcorder
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
Can't download
USB bad. If the footage is on hard drive rather than tape just browse the camera or import rather than capture. If difficulties seeing the hd maybe use a card reader known to work with mac. If it is on DV tape you need to connect to a dv / hdv out to fire wire, if this camera doesn't have one you will need to borrow some one's who does.
May 31, 2009 | Canon FS100 Flash Media Camcorder
Cannot download video, only Card pictures
I do not know MACs, but a standard 4-pin to 6-pin firewire (IEEE1394) is needed. On Windows XP, plug it in, run Windows Movemaker and you are good to go. By the way, a "DV cable" is a firewire cable.
If your MAC cannot "see" your camcorder, try another firewire device to see if your MAC is the culprit, or drag your camcorder and firewire cable to a friend's PC running Windows XP and see if it works.
May 27, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Canon HV10 not recognized
It appears that you are missing a driver from Canon for your camera. FireWire is an unusual interface and most PCs were not plug-and-play for this interface.
Sep 21, 2017 | Canon HV 10 HDV Digital Camcorder
My canon HV20 do not connect with my dell studio 15 laptop
do yuo have an external hard drive connected...that will interfere with the connection sometimes, hdv/dv should appear in solid whilte letters unders stereo1 in the lcd on the camcorder screen, and what version of vista is it and is the firewire cable plugging directly into the pc...if it doesnt work in one port try another in different location on it.
Nov 25, 2008 | Canon VIXIA HF10 HDV Camcorder
Canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Nov 16, 2008 | Canon VIXIA HV30 DV Camcorder
Canon optura is not connected to my pc
make sure you are using firewire only-not usb-if you are using firewire the computer should recoginize the camcorder as soon as you plug it in
May 08, 2008 | Canon Optura 30 Mini DV Digital Camcorder
Canon VIXIA HV30 DV Camcorder Logo
5,278 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
