Question about Toshiba TZ50V51 50" Rear Projection Television
To clean the screen?
How about the procedure for cleaning and hopefully scratch removal on the front screen?
  • 125 Answers
Is it the shield or the screen itself ?
Posted on Oct 24, 2008
  • Jose Posada
    Jose Posada Nov 06, 2008
    there is no way to remove the scratches from the screen I tried different ways
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
How do I remove scratches from the screen of my Sony Ericsson w995a phone?
I think, it depends on the scratch of your phone. But try using a small clean cloth or a cotton to remove the scratches. If its just a light scratch, maybe it will budge off.
Hope this helps! -jayps
Mar 15, 2011 | Sony Ericsson W995a Cell Phone
While i was cleaning my Sony Bravia 40 Inch 1080p Flat panel LCD Screen, it had alot of dust so i used some cloth while i was cleaning it with cloth it made some kind of lines... scratches the scratches...
only use microfiber cloth to clean LCD panels, and no windex. Use 50/50 distilled water and denatured alcohol, or a dedicated LCD cleaner. Small scratches are not worth buffing out as screen itself is relatively soft plastic.
Oct 19, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
There is a green hue around the objects and people on the screen how do i fix this
Hope it is just cleaning take off the front screen. I think on that model remove the speaker covers, and a row of screws holding the bottom of the screen remove them. Watch the wires to the front buttons there may be a connector or two to undo. Carefully lift up and toward you WATCH THE WIRES. With a dry clean cloth wipe off the three CRT tops and the back mirror. Put back together and see.
If you still have a green hue.
Remove the screen again. With a flash light look down the CRT's if they a real cruddy down in the coolant yes there is liquid coolant in them. The red doesn't have this trouble but the blue and green can get contaminated. Also look for leaking of the coolant down on the boards. There are procedures to clean and repair leaks. Let me know.
There are a couple of focus procedures which I don't think is your issue.
Good luck Mark
Oct 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Kp46wt510 rear projection . The words are blury on the screen.
Before starting this DO NOT SPRAY CLEANERS IN OR AROUND TV or change factory adjustments.... OK now that's out of the way first remove the front face you should see 3 lamps gently clean each with a clean rag move to the large mirror in the back clean it well then to the lenticular lens or the front screens use microfiber rags these are plastic and easily scratched this should not only clear up the image but make it brighter do this every 6 months to a year................. I hope this helps
Jul 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Scratched Finish on Screen While Cleaning
Here are some solutions to consider. Try in an inconspicuous place first.
1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
3)You may also get commercial LCD scratch removers on the 'net.
An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
Mar 13, 2009 | Sony Televison & Video
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
