Question about Refrigerators
Amana Fridge - Not making ice
i have a Amana SRDE 528VW and it has stopped making ice. The ice bucket is empty and it is in place properly. The metal arm is also clicked down too. The fridge is dispensing the water. ?????? Please help..
  • jvdplg Nov 03, 2008
    Icemaker is not making ice. No suggestions for troubleshooting in the manual. The fridge dispenses water. Any suggestions?
    HELP
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
Lg fridge not making ice all of a sudden
It just may actually be frozen lol. Try defrosting the freezer and see If it works after that
Nov 27, 2017 | Miscellaneous
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Amana bottom freezer, model abc2037dts, there is a motor noise that goes on for 8 seconds then shuts off, then a few clunks for 2 seconds
Even if you do not have the water hooked up for the dispenser and ice maker, the fridge still makes the sound as if it is filling up the ice maker. If you lift the metal arm beside the ice maker, the sound stops happening because it thinks that the ice bucket is full.
Aug 08, 2010 | Refrigerators
Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
Hi
Firstly put off the refrigerator before the compressor burns off.
The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
Regards
Berry
Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
Amana icemaker not making ice
Just had the same problem,when I pulled the fridge away from the wall I noticed the copper tubing running from the water source had a kink in it. Got a new line and problem solved it also mentions this in your manual under trouble shooting.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
Nov 29, 2008 | Refrigerators
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
I have an Amana fridge with an internal ice maker. It suddenly stopped making ice. The lever that moves up and down popped out and I put it back in but now there's no ice. Can you help?
hi thanks for the question is the arm in the down position and is the arm put back in its proper position check that thanks please leave a positive feed back the appliance doc
Sep 24, 2008 | Refrigerators
On our Amana Side by Side, there is water dripping from the ice-maker bucket. The cubes were melting. It does not appear that anything else below is melting. I emptied the bucket and lifted the arm to stop...
I don't have this particular model, but had a similar problem. Check the flap to the ice chute. If it's not sealing properly it would allow warm air into the freezer and melt the ice.
I had to call for service.
Jun 12, 2008 | Amana Refrigerators
Refrigerators Logo
234 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
