Question about Emerson iPod Stereo Clock Radi Docking Station, Remote Control, Clock Radio
Emerson iPod Clock Radio Docking Station #IC200BK radio
I can seem to get my radio to turn on. I can get it to turn on for the alarm and if I press sleep but it only last for a little while but whenever I press the power button nothing happens. Please help!
  • AMannwieler Mar 02, 2009
    I cannot get the radio or IPOD to work.
    This is So Frustrating!
I was having a similar problem with my ic200bk stereo dock. After unplugging the machine, replugging it, and allowing the auto set to occur, a timer is activated while nothing else works. I spoke with an Emerson employee about the problem, but he wasn't very helpful. He simply indicated the unit needs to be repaired (which, conveniently, they don't do) or replaced (by only if your 90-day warranty is still in effect...also convenient for me). Bottomline: your unit is **** is Emerson can't (or won't) do a thing about it.
I'm done with Emerson forever.
Posted on Aug 24, 2009
How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
Setting the clock for the Ipod docking station
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
NO sound coming out....from iPod or radio Volume turned up ...
No solution, but my iHome iH8 has the exact same problem. Took the bottom casing off to see if I could find a speaker fuse or reset button. No luck...
Oct 26, 2009 | Apple iHomeaudio iHome iH8B Dual Alarm...
Instruction manual for innova docking station
They do not exist. I was not given instructions with mine. Now its only function is an Ipod charger and speaker.
Jan 30, 2009 | Innovative iPod Clock Radio with Dock...
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from It is also supposed to be under the support section of the website but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Sep 01, 2008 | Emerson Smartset Clock Radio
Emerson IC200BK smartset iPod radio - buttons seem to be stuck
You can try taking the battery out and let the microprocessor discharge it charge and unlatch the switch controls function. This should take about a hour to be safe. To do this take the plug about from the wall also. The battery may be bad and need replacing. You can test the battery by putting it back in after you test the radio and clock with the a/c plug only. After the radio and clock return to normal operation. Put the battery back in and see if it work properly and all the function work. If you are still having problems replace the battery. If this does not fix the problem, you will have to call Emerson customer support at this telephone number 1-800-898-9020. Give them the model number of you clock radio and tell them the problem you are having with the failure of the front panel buttons. They will be able to tell you if there is a fix or if you have to send it in for repair. I hope this information helps you with your problem.
Aug 26, 2008 | Emerson Smartset Clock Radio
Emerson iPod Stereo Clock Radi  Docking Station, Remote Control, Clock Radio Logo
285 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
