Question about Bernina 1008
Trying to sew a buttonhole on my Bernina 910, and keep breaking needle.... cannot figure out how to center my needle. Position 1 for the buttonhole process moves it too far to the left and automatically breaks needle.
    Genius:
  • 1,124 Answers
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
    Brigadier General:
  • 3,614 Answers
One of this should be check.:
  • A thin needle was used for sewing a heavy weight material- Use correct size needle of correct type.
  • Needle has not been fully inserted into needle bar- Properly insert needle.
  • Needle clamp screw is loose- Securely tighten needle clamp screw.
  • Presser foot is not correct one- Use correct presser foot.
  • Presser foot is loose- Reset presser foot.
  • Pulling on fabric as you sew- Do not pull fabric, guide it gently.
    President:
  • 1,952 Answers
Pls tight ur button hole foot...while inserting needle
  • mohammed marika thambi
    mohammed marika thambi Oct 18, 2008
    change the Presser foot buttonhole
    only problem getting in just the right size button use
    you can put the buttonhole twist right on the foot
    and it tucks it into the buttonhole nicely. hardly ever make a buttonhole
    without the twist. keep the spool on the second spool holder on top of the
    machine.
How to replace needle in bernina active 240 machine, needle keeps breaking help please
Check to make sure you are installing the needle facing the correct direction--usually the flat side faces toward the back of the machine. Also, is it the correct needle--130/705? Is the needle pushed as far up as possible before it is tightened? Check the machine by handturning the handwheel rather than trying to run the machine.
If those check out, then it's quite possible the machine is knocked out of time. Take it for service. Refrain from trying to sew as long as the needles continue to break. It could cause more damage--costing more to repair..
Oct 09, 2017 | Bernina Sewing Machines
Berninamatic 910 is frozen. Where can I find manuals so that I can service it?
Ken--
May be difficult to find for your machine because of its age.
Something may be close on this Bernina site (the 910 looks a lot like the 930 without the basting stitch, perhaps the needle up/down function, and fewer decorative stitches):
https://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
BERNINA MATIC 910 ELECTRONIC SEWING MACHINE MANUAL CD
Most likely the machine has seized due to lack of fresh oil. The old oil has solidified and turned to glue and has stuck the moving parts together. Do not force it!
Remove the free-arm cover.
Open the top. (There is a metal peg on the top left with a screw slot in the center. Turn this screw 1/4 turn. Now lift the bobbin winder and you will see another METAL screw. Turn that 1/4 turn. Do NOT mess with the plastic screw unless you want to mess up the winder.) Now you can gently lift off the top. Pay particular attention how it fits as you will need to jimmy it a bit to get it back on without bending anything!!!
Now you can remove the cover on the left side over the needlebar.
Pick up a bottle of liquid Tri-Flow Synthetic Lube (hardware store or bike shop) with the small plastic tube dispenser. Gently rock the handwheel and apply a couple drops of Tri-Flow every place that metal rubs on metal. Do NOT oil the white nylon gears, the cams, or the belt!!! If you look closely, you will most likely see some small holes that are actually oil ports. There is a large one just on the inside of the case (left of the belt) that is part of the handwheel mechanism. This is probably where your problem exists. Do NOT over-oil or you'll be cleaning up oil for a long time and it could get into the electronics.
Work your way across the top of the machine. Be sure to move the stitch selector levers, the buttonhole knob, stitch width dial, etc and get oil into those metal mechanisms as well. There are 4 or 5 oil ports on the needlebar knuckles. Be sure to get those--one or two may be hidden so you'll need to rotate the handwheel and use the long tube to get to a couple. Oil the needlebar where it goes through the case, be sure to hit the presser foot lever mechanism.
Work your way down to the bobbin area. Be sure to get the oil port at the very back of the feed dogs next to the case (this is a very important one!). Get oil on all the metal moving parts and be sure to toggle the feed dog knob and get that mechanism too.
Now, take a handheld hairdryer and direct hot air into the internal mechanism of the machine. I've gotten the metal so warm it was difficult to touch. You may need to alternate between oil and heat, but if there is nothing mechanically wrong with your machine, this will get it running smoothly again. I've used this method on several seized mechanical Berninas and it has never failed unless a nylon gear is cracked or there is something else mechanically awry.
For sure, every time you start a project, apply a couple drops of oil where the hook and shuttle rub together (see the bottom photo below, the very bottom arrow on the left) or see page 45 of the Bernina 930 manual (Maintenance section).
Be sure to lube your machine often. Once you are familiar with the sound of a smooth-running machine, you will recognize by its sound when it needs some TLC. Other than that, plan to lightly oil every 40 hours of sewing. If in storage, every 6 months whether in use or not.
The photo below is actually a Bernina 830, but the mechanism is fairly similar to the 930/910.
Oct 09, 2016 | Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
The 19, 20 and 21 dials on my Bernina 831 sewing machine are stuck. What should i do?
Is your button hole dial activated? Sounds like a dumb question but if the indicator on the buttonhole dial is not at the top it will lock the other dials. The only other thing is that if above is correct, you will have to find a dealer who can carefully oil and get the dials to rotate again. It is v tedious and one has to often disassemble the stitch width, needle position dials and carefully force the buttonhole dial while lubricating the mechanism to get it all working again
Aug 01, 2014 | Bernina Sewing Machines
Record 930 Electronic, breaks needles in reverse on buttonholes
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 14, 2012 | Bernina Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
365 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
