My hpr povilion ZV6000 won't on
When i gone back from my office and i press the power butoon of my notebook it won't on when i saw the adopter was in electricity if the adopter discunect and reconect the charging light is on for 3 or 4 secnd after that it off and the computer dosn't on what shoud i do
No power,power indicator led won't lit.
Hello
That means that you have a problem with the power of your unit check the power adopter by a voltmeter if there is a 5 volts output if no voltage detected check the power source where your adopter is plugged. If there is an AC output on the outlet, check the output wire of the adopter. If the wire of the adopter have no problem on the connection check the socket where the output of the adopter is being inserted try to squeeze it while the adopter is being plugged to the AC. If the problem is still there look at the sticker of your unit if under warranty, if under warranty return it to the store where you buy it to avail the free service warranty. But if not under warranty you can fix it if you have a little knowledge in electronics. Because there is an internal damage on your unit either the power adopter of the unit or inside the unit.
If the adopter is only the problem you can open it by removing the one screw on the back of the adopter. See to it that the adopter is unplugged, then check the fuse of the adopter it is a small tube like component you can test it by a multi tester if there is a continuity it means the fuse is not busted but if no continuity it means you have to replace it with the same value. The second one is if there is a bulge capacitor. It means that if there is a capacitor that change there original shape, sometimes it blow sometime it just pop on the top of. Replace if there is a capacitor with look like that, Replace it with the value in farrad and in volts.
Hope this solution will help you
Sep 02, 2011 | KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV...
Lexmark X5270 power butoon keeps blinking and no power
Try to remove the power adapter from the printer. Then unplug the power cord from the power outlet in the wall.printmastert_62.jpg
Wait at least 10 seconds before re-plugging the printer into the power source (bypass any surge devices or power strips). Reconnect the power adapter into the printer. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for further assistance.
Jun 26, 2011 | Lexmark X5270 All-In-One InkJet Printer
My screen is not coming on now as it worked today
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
5.if you will get the same problem again means suspected issue with main board.
Nov 22, 2010 | Acer Aspire 3100-1405 Notebook
Gateway m-6846 don't turn on neither ac adapter nor battery
4.boot your system
Nov 22, 2010 | Gateway M-6846 Notebook
The screen on my Acer Aspire won't turn on?
do one thing
4.boot your system
Nov 18, 2010 | Acer Aspire 3100-1405 Notebook
Aspire one won't turn on, on switch illuminated but no display on the screen. battery light on but no other lights.
4.boot your system
Nov 16, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My screen is not coming up all when i on my system
4.boot your system
Nov 16, 2010 | Dell Vostro 1310 Notebook
How do i reboot my HP Pavilion zv6000
press together ALT+CTRL+DEL it will reboot
regards
Apr 27, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
