Pacco group ix my ciu p4 2.66ghz 15" tft
Where can I get a new power supply for this unit and how much it cost I am using a IX PACCO and the Power Suplly sufer a electrical damage, maybe or shure for bad conditions of my ac connection (ground problems), and now i am using an external (and uncomfortable to move the PC) power supply. Where i can find better the correct replacement, if i visited the PACCO Group page, and they said that there is not more units. It will be temporal?
  • kensblownbik Apr 01, 2009
    cant program satelight remote to tv no code?
  • Anonymous Apr 28, 2009
    same problem
  • 59 Answers
Try ebay I find a lot of hard to get parts some new some used there
Posted on Oct 30, 2008
Will this isp 120s power supply work with a newer mother board which has the quad connection that looks like an 88 does it need (or does not need) to be plugged in?
Hello Eddie, Hi, the modern motherboard definitely needs the 88 or 12 volt quad connector, if the power supply is missing that connector, it will not work, except for the INTEL 510MO board which do not need the connector, so check this out. http://www.logicsupply.com/products/d510mo. If you want to use this power supply on other boards, ask a local computer shop if they have a bad power supply or if you have one to salvage the quad connector and solder it on the PS unit. The connector should be soldered on the 12 volt yellow wire group and the black wires goes to the black wires group. Ive done this and it works.0
Feb 24, 2011 | E-Machines Emachine Ilssan isp 120s isp...
Tip
Laptop is plugged in but says it is running on battery.
You have your laptop plugged in but when you check it says that you are running on battery. Or, you have your laptop plugged in and it will not work because the battery is dead.
Both scenarios depict a broken power port on the laptop or possibly a bad power supply. Checking the power supply is easy. Using a DMM on volts DC set to 20 place the red lead on the center pin and the black lead on the outside of the plug assembly. If you do not have the correct voltage as listed on the power supply then you need a new one. While holding the leads on the power plug wiggle the wiring to make sure there are no breaks. If the power drops to zero at any time you need a new power supply. A good site is http://www.impactcomputers.com .
Many times people do not realize that their power port is broken until it is too late. If you continue to use your laptop after the port is broken you will destroy the power supply portion of the mainboard and it will cost you half as much as the laptop cost to repair and may make it not worth fixing.
When you realize that your laptop is not running on AC power, and it could be intermittant, you need to immediately take it to a repair facility to get the jack replaced. The average cost should not exceed $150 US.
This is not a repair procedure that I can walk you through. You can only get your unit repaired at an experienced reapair facility.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Nov 13, 2010 | Computers & Internet
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 25, 2011 | HP ATX-400W, ATX-400W Rev. T1, HP P/N:...
How can i repair a power suply
9 times outa ten there is a small 2.5 amp fuse inside.
you will have to desolder it and er-solder a new one in.
Oct 07, 2010 | RaidMax 350W Power Supply...
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Orange connectors (3.3v) brown
thats probably dust and static dirt, if the power supply worked fine before then there should be no problem providing that the pin arrangement is the same, test it on you old mobo to check it!!!!
Nov 14, 2008 | HEC Group ACE 580UB 580-Watt Power Supply
Power Supply Unit
Hi harry_p58,
It's not really cost effective to repair power supplies such as the one that you have. You can get a new high-quality power supply at very good prices these days (which will be cheaper and more reliable than trying to bring your old one back to life)
Hope that helps,
Take care,
Michael
Nov 13, 2008 | Newton Power (NPS200PB108D) 200-Watt Power...
Power Suply Replacement
Any good computer supply company should handle power supplies. The important thing is to get one rated for the same power. (300W, 350W, 400W, etc.) You can always go higher, but not lower.
Oct 18, 2008 | Computers & Internet
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Open Questions:
Computers & Internet Logo
357 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
