Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
IPaq rx3115 won't charge!!!
Sonic Freak on Oct 18, 2008
I have an iPaq rx3115 that will not charge. I tried charging it on the computer, with it's charger, other bable, tried replacing the battery. I left it charging for more than four days but nothing. It works only when charging, but doesn't really charge. Can someone tell me what's up?
SONIC RULES!!!
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Feb 12, 2009
-   HP iPAQ RX3115 wont turn on unless its charging. If i unplug it, it does a complete reset.-   Guest
Nov 30, 2008
-   My iPAQ RX3115 will NOT operate unless on charge, and when on charge it does not fill up the battery! HELP!!!!!!!! -   Guest
Related Problems
I seem to have a slow SD card interface and wonder if this...
For the past two years when it has been time to change to...
my ipaq hp pda Rx3115 does not have the right time as my...
My ipaq locks up after resetting.  Will not go past align...
Can you Help with these PDA problems?
charge for ipaq 3417 does not show...
Solve
I have the same problem i am working it on it i replced the broken lcd screen after that there has... (More)
iPaq rx3115 working like PC not...
Solve
I have an Ipaq rx 3115. When i got into my settings it lists my AC only has the main battery and the... (More)
the last time i was charging my...
Solve
the last time i was charging my iphone it refuses to charge
Windows Media Player 11 for hp 3115...
Solve
How can I get WMP 11 (instead of WMP 9) on my hp iPAQ 3115?
can someone tell me how to install...
Solve
can someone tell me how to install the lcd screen for this ipaq
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(562) 366-0079
On-Site Service 24/7. Home & Business IT...
RTS Technology Group, Inc.
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
