How to unlock toshiba satellite a305 s6825 laptop
My son was going to shut down my laptop but, he accidentally click on lock and now the laptop just went lock mode on me. I don't know how to unlock the laptop and the screen went blank and I have no clue how to fix it. I'm using my friend computer to write to u guys. Can someone please help me?!!
  • leubank Dec 10, 2008
    I have the same problem. I have tried Fn and F1, backspace, I've taken the battery out. Nothing is working. We do not have a password set up.....any suggestions???
My toshiba laptop audio function has been locked and I would like to unlock it via bios but cant find the correct function or description to unlock.
can you give step by step instructions
Posted on Nov 19, 2009
    Genius:
  • 1,124 Answers
To Lock your computer you must hit F1 or Fn + F1
To cancel or unlock hit "Back space" or a small key with a arrow with a curve like a simbol "loop" same image showed on the tape recorders autoreverse (very hard to explain)
If you hit Fn + F1 this lock automatically your computer and only the principal user (who knows the pass can get in)
You can download the manual of your laptop here:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Check the page 231
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
  • 4,338 Answers
Hold the Fn key and hit F1 key.
Here is the manual:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1994928xml&sliceId=&dialogID=56250844&stateId=0%200%2054433408
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Shuts down after a few minutes
Try another battery.
If it's doing this while plugged in, there's probably failing electrolytic capacitors in the external power unit. Repair or replace it. Chances are the power supply will test as good under no load.
May 15, 2012 | Toshiba Satellite A305-S6825 (4400 mAh)
Where can i find a cord for toshiba satellite 8305-s6829
If you are referring to the AC Adapter, you can find out here:
http://www.buy.com/prod/new-ac-adapter-for-toshiba-satellite-a305-s6825-a305-s6829-a305-s6833/q/sellerid/24353325/loc/101/214314182.html
Otherwise please specify the type of cord you are looking for.
May 05, 2011 | Computers & Internet
My refurbished Satellite A305-S6825 boots up to a blue screen and nothing else . . .the mouse moves but nothing shows on the screen and it just sits there!
Just do onthing..
Once you get blue screen, Press ALT +CTRL+DELETE Key and you will get windows task manager. There you need to go to FILE and select New Task (RUN ) and type explorer.exe and press . Now you can see the icons on desktop. If still you are not able to get icons you have to format or Repair the operating system
Mar 30, 2011 | Toshiba Satellite A215-S4697 Notebook PC
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Toshiba A305 shuts down randomly. Hard drive replaced twice by different service companies. Still shuts down. Upon startup and after its been on a while. Any ideas?
More than likely it's from heat. The A305 gets hot quick, especially if your model uses the AMD processor. I would suggest you cleaning the machine out with some compressed air and verifying that you are running the latest bios revision for your model.
I've fixed lots of A305 just by doing the above ;)
Give that a shot, if it doesn't work let me know and I'll suggest more things you could try...but I'm pretty confident heat is causing your issues.
Jan 13, 2011 | Toshiba Satellite A305-S6863 Laptop
I have a problem with my laptop toshiba a305-S6825, everytime i plug in the ac charger the laptop shuts down and reboot. I can only use the battery. I have to shut down the laptop everytime so i can charge...
try to press start button and then search for device manger then click on the battery and find out its condition wither it needs to be replaced or it may some programmes need to update by pressing trouble shoot
Sep 14, 2010 | Toshiba Satellite A305-S6845 Notebook
What are the slots on the bottom of my Toshiba Satellite A305 S6825
The slots on the bottom of your laptop are for air circulation. Used with a laptop cooling system to push air through the bottom of the unit and circulate out the side vents. There may also be vents on the rear of laptop for the same purpose. Hope this helps you with your problem.
May 11, 2009 | Computers & Internet
Graphics card
laptops are difficult to upgrade
most are proprietary
you'll have to call them 800-316-0920 and ask if you can buy a video card upgrade for this laptop
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
3,911 people viewed this question
David Payne
David Payne
