Question about Sony NW-A1000 MP3 Player
Ipod Hangs hi, I have NW-A1000 i-pod and frequently my ipod hangs when i switch on and goes off, afterwhich if i start again it works perfect.The gap between these occurence is between 3-4 hours.
  • 82 Answers
U've an IPod? Dude why wasting time with NW?
Posted on Jul 11, 2009
    Genius:
  • 1,226 Answers
Connect your ipod to the computer and then sync using the itunes software.
may this help.
melnavz
Posted on Oct 18, 2008
SOURCE:
Hang-up
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Take care.
Apr 14, 2010 | Apple iPod nano 3rd Generation
Tip
How to reset ipod, hangs can't turn off, hang on apple logo
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
on Jun 20, 2010 | Apple iPod nano
My nano hang!
If your ipod just hangs, have you tried doing a reset by holding the menu and middle buttons?
If that doesn't work, before you connect it to your laptop, make sure that you have the latest iTunes loaded on your laptop.
Hold the menu and middle buttons until the screen goes black and then quickly hold the middle and play/pause button until you see a checkmark and the words disk mode. Now connect it to your computer and do a restore.
If it doesn't check the connector at the bottom. You may have some bent pins in the connector at the bottom. Unfortunately, that will cause communication problems with the computer and ipod. Hope that helps.
Oct 28, 2008 | Apple iPod nano
Ipod video hangs
Sounds like you might have a Hard Drive Issue or a logic Board Issue we can defiently help you on this for Repairs straight away please contact us at 661-619-5928 or email us at sales@ipodrepairz.com or check us out on EBAY under our seller's name ipodrepairz and you will see our Free iPOD repair service that we offer.
We look foward to your business and also repairing your Broken iPOD
Thanks Again
ipodrepairz
Sep 16, 2008 | Apple iPod MA446LL/A MP3 Player
4gb nano ipod hangs
flick the hold button back and forth a few times, then, making sure that it is unlocked press and hold the menu and middle button together. hold them down until it goes dark and the apple mark comes up. hope this helps?
Aug 18, 2008 | Apple iPod nano
Sony NW-A1000 will not play,
If you get the spinning disc error on your sony nw a1000 it means the hardrive is knackerd.
The hardrive in the sony NW A1000 is a segate ST1.2 6gb and these can be bought off ebay for around £8. If you can't find a 6gb one you can fit an 8gb hardrive BUT your NW A1000 will only use 6gb of it.
If you search on the internet you can find instructions on how to remove the back cover of your NW A1000 which is very easy to do! You then unplug the hardrive (be very careful!) and replace it with the new seagate hardrive. Turn the NW A1000 on and go to the home menu, select "settings", then select "intialize disc" and it will format your new hardrive so that it can work with NW A1000.
Jul 02, 2008 | Sony NW-A1000 MP3 Player
IPod nano 8gb problem. Just hangs ........ Shanni
hi
turn your hold button on
press and hold menu + select (center) buttons at once until the ipod goes off, so it will restart with the ipod logo. if it that is done successful it will work without any problem.
If the problem persists scan the ipod for any viruses.
if that doesnt work you wil have to use itunes to restore it but with this you will loose all your data.
wish you luck
Jun 19, 2008 | IBM NetVista PC Desktop
4gb nano ipod hangs
try letting the power run right down then recharge. It works for my 2 gig
Dec 25, 2007 | Apple iPod nano
Apple ipod
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Just Hold the center button and the Menu button until the screen goes blank and the apple logo shows up
this is called a reset
Nov 22, 2007 | Apple iPod nano
Sony NW-A1000 MP3 Player Logo
167 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
