Question about Dell 0Y3740 Keyboard
Want numlock on as default at start up
Work networked computers previously had numlock on as default at start up and log on. But now default is off. This is a pain, especially since my password is mostly numbers. Also no need for numlock as arrow keys and home etc keys have their own dedicated keys anyway so number pad does not need to be dual use. Tried control panel keyboard but no option there. I don't have administrator rights so maybe not seeing the option. Asked IT and they were as useful as they usually are.
Thanks
Tomu
  • jhenson449 Oct 18, 2008
    I pressed F2 but the only keyboard bit I could find was in post behaviour
    it had a numlock option which was already on and toggling it had no effect -?something to do with self test status?
    Either works new dell doesn't have this opion in bios or I am too stupid to find it but sounded promising
    thanks
    President:
  • 1,901 Answers
There is an option in the BIOS setup to turn the NUMLOCK ON when the computer boots. If you know how to get to the BIOS, it should be easy to find on one of the menus.
If you do not know how to get into the BIOS, watch when the computer first begins booting. It should say something like, "For Setup Press <Whatever Key>". You only have a few seconds to press the stated key. Once in, search for the option for NUMLOCK. When you are done look for "Save and Exit".
Posted on Oct 18, 2008
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
Tip
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
on May 20, 2010 | Computers & Internet
How to block people from useing your router
You can set up a password to access your wireless network. Please follow these steps in order to enable wireless security:
  1. First you must open any web browser on a computer connected to your network (I reccomend plugging in your computer directly to your router using an ethernet cable instead of using a wireless connection for this process.)
  2. In the URL bar type in the IP address of your router (most likely 192.168.1.1). If that is correct you will see a log in screen.
  3. At the log in screen input your user name and password for the router. If this is your first time configuring your router input the default user name and password (most likely "admin" for both.) If you are unsure of your user name and password you can find the defaults at this website: http://www.routerpasswords.com/. If the default does not work you may have to reset your router to factory default by depressing the reset button on the back of your router for 10 seconds (WARNING: this will reset all previously configured settings on your router.)
  4. Once you have logged in navigate to the Wireless or Security tab, depending on your router.
  5. Under security type select WPA2 Personal (some older wireless devices will not be compatible with this setting, if you have older devices use WEP)
  6. Create a passcode for your wireless network and select Save at the bottom of the screen. If you are currently on a wireless connection you will be kicked off so make sure you write the passcode down before you save.
Congratulations! Your wireless network is now secure and only people you have given the passcode to can access your wireless network.
Sep 17, 2012 | Linksys Wireless-G WRT54G Router
Where can I find the password/key for my netgear wireless router
Do you mean the key to log onto your wireless network? Plug a computer directly into the wireless router via the ethernet cable and go to 192.168.0.1. or 192.168.1.1in Internet Explorer. I believe one of those default address for netgear routers. Login to the router, the default login is login:admin password:password then select 'wireless settings' on the left and you should see the key.
If any of the default info has been changed and you cannot login, you will need to reset by pressing the reset button for 30 seconds. But you will have to reconfigure the wireless network and reconnect all computers that were previously connected.
Nov 06, 2010 | Computers & Internet
How to activate NumLock as a default? My job requires that I work with numbers the majority of the time so I need to keep the NumLock active. However, each time I log off, the NumLock automatically...
A simple reg edit will do this
For current user:
  1. Start Regedit
  2. HKEY_CURRENT_USER\Control Panel\Keyboard\InitialKeyboardIndicators
  3. Change the value from 0 to 2
For all users:
  1. Start Regedit
  2. HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyboardIndicators
Jul 09, 2010 | Dell SK8110 Keyboard
When i typed my password it dosent enter to the setup.
his causes the customers to have troubles logging into Windows if they wont notice the numlock status.
Here's what you need to do.
1. Start the system up
2. When on the logon screen, turn the numlock OFF(FN+numlock). Do not login yet, instead restart the computer via the power button.
*The numlock should be off by the next reboot.
Mar 03, 2010 | Acer Aspire 5520-5908 Notebook
Num lock is default on, even when I don't have a keyboard attached. Every time I boot up, I have to turn off num lock just to be able to type my password and log on to my PC. How do I fix this?
NumLock should not affect your login at all. It still allows you to type in alpha-numeric.
If you want to switch off auto-numlock, go into your BIOS as your computer boots up and change the setting which triggers it.
Nov 12, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
NumLk issue
I found the following at:
http://www.freshmango.com/support/kb/office-business-programs/windows-xp/xp-numlock-issue-on-login-startup/
This should do the trick...
After some search I discovered that the Numlock control status can be controlled using a registry key which can be found here:
HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard \ InitialKeyboardIndicators
Simply change the value to either 0 for off or 2 for on.
  1. Start the Registry Editor
  2. Go to Start
  3. Select Run
  4. Type regedit
  5. Work through the tree to get to HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard
  6. If the key “InitialKeyboardIndicators” already exists then change its value to the appropriate number, if not, add a new key called “InitialKeyboardIndicators” with the appropriate value.
  7. Click OK
  8. Restart
For the lazier amongst you, simply copy and paste the code below in to a text file (in notepad), save it as "FixMySoddingNumlock.REG", close notepad and double click the file:
To make the Numlock OFF by default use: Windows Registry Editor Version 5.00
[HKEY_USERS\.DEFAULT\Control Panel\Keyboard]
"InitialKeyboardIndicators"="0"
To make the Numlock ON by default use: Windows Registry Editor Version 5.00
"InitialKeyboardIndicators"="2"
Oct 18, 2009 | Panasonic Toughbook 50 Notebook
Will show avaliable wireless networks but won't connect
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
if the Issue presist then you need to try System restore
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page(try the date 2 dats prior it was working or the First Bolded Date of that month), click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK.
Aug 09, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Bizhub C252 -- printer defaults not retaining account tracking passwords
when you create account codes they are assigned a number, are you sure you are not starting at the end? It should only erase the previous information if you turn account track on then off.
kevin.hayes@bt.konicaminolta.ca
Oct 26, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Dell 0Y3740 Keyboard Logo
273 people viewed this question
Alun Cox
