Question about Samsung DLP HL-P5663W 56" TV
DARK HORIZON AREA AT TOP OF SCREEN
HELP, I TURNED OFF MY TV ONE NIGHT AND IT WAS FINE I WOKE UP THE NEXT DAY AND THERE WAS A DARKEN AREA AT THE TOP OF THE SCREEN THAT EXTENDED FROM ONE SIDE TO THE NEXT AND THEN THE DARK AREA DIPS IN THE MIDDLE OF THE SCREEN, NOW THE PICTURE IMAGE IS DISTORTED, THERE ARE DUPLICATE IMAGES AND EACH IMAGE HAS A DIFFERENT COLOR, THE NUMBER THAT DISPLAYS TO SHOW WHAT CHANNEL THE TELEVISION IS ON, NOW HAS BEEN DUPLICATED. WHEN THE SET IS DISPLAYING AN IMAGE THE DARKENED AREA TAKES ON A YELLOWISH COLOR I DO BELIEVE. THE SOUND IS OK AND YOU CAN MAKE OUT THE IMAGE IT IS JUST REALLY DISTORTED WITH THE "DUPLICATE IMAGES" THAT IS THE ONLY WAY i KNOW HOW TO DESCRIBE IT. ITS LIKE THE MAIN IMAGE HAS 1-2 HALOS OF ITS SELF THEREBY GIVING A BLURRED APPEARANCE, I CANNOT AFFORD A NEW SET "56 INCH SAMSUNG". PLEASE HELP THANKS IN ADVANCE
  • lelemoon Mar 18, 2008
    I am having the same problem with my samsung hl-s5687w 56 inch dlp tv. All of a sudden there is a dark area extending approximately 2 inches from the left of the screen extending top to bottom.The picture however is not distorted
  • peteralkins Sep 09, 2008
    TV is Samsung HCN4226WX/XAC
    Exactly the same problem.
    Tried to resolve by (1) turning TV on and off; (2) unplugging power and then reconnecting power; (3) perfecting image function tried.
    Peter Alkins
    peteralkins@hotmail.com
  • 53 Answers
Not sure but you could have a bad color wheel i would suggest a service call from your local shop
Posted on Jun 08, 2006
  • 3 Answers
I had an almost identical problem -- a very dark bar along one side. There was a tiny bit of image there, but it was like looking through a strip of very dark glass. I did not have duplicate images or funny colors. Samsung replaced the light engine under Best Buy's (their Magnolia subsidiary's, actually) extended warranty, and everything was perfect again.
The technician said that there is a felt-like lining in the light engine to prevent unwanted reflections from stray light, and that the adhesive that holds it comes loose allowing it to block the light from hitting the edge of the screen, resulting in the dark bar.
Posted on Mar 23, 2008
The calculator crashed two times several days ago while I was using it. It worked fine the following day, but after that the screen became very dark. So dark that I need a flash light shining at it to see....
I will address one part of the question only: I will avoid the speculations.
How to change the screen contrast
  1. (TI-Nspire with native keyboard): With the TI-Nspire keyboard in place,
  2. Press the ON button to turn calculator ON.
  3. Press and HOLD the Control key [CTRL]
  4. Press [+] to darken the screen
  5. Press [-] to lighten the screen (Your case)
  6. Stop when contrast is adequate.
  • TI-Nspire with TI84PLUS keyboard: With the TI84PLUS keyboard in place
  • Press the ON button to turn calculator ON
  • Pres the [2nd] key and RELEASE it
  • Press the [UpArrow] of the NavPad to darken
  • Press
Feb 15, 2010 | Texas Instruments TI-Nspire Graphic...
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My tv has sound but screen is totaly black
hi..
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem..
thank u
rate me
Jul 26, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Television has audio but no video
Hello blondemommy0,
This sounds like your inverter or back-light has gone out. What you can do to test this is to turn the TV on and then turn off all of the lights until the room is dark. Then shine a flashlight at an angle on the screen and see if you can see a picture. If you can the back-light and or inverter has malfunctioned. If this is the case, then I would suggest that you have a qualified TV technician fix this problem, but first ask for a estimate because the inverters and back-lights are sometimes part of the screen and is it is you might as well buy a new TV.
I hope this helps,
Thank you,
Shuttle83
Electron-Age Technologies LLC
www.electron-age-technologies-llc.com
Nov 15, 2008 | Sanyo DP32746 32 in. LCD Television
Screen darkness
Just fixed mine.Remove the back of the TV on my model there in a small pwer supply turn the bottom of the two pots this will darken or lighten the screen. Fine tune with the settings on the remote
Jul 04, 2008 | Televison & Video
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Sgh-e315 will not turn on
the phone needs to be reflash so take it to a mobile service center and ahve them reflash it for you.
Sep 05, 2007 | Samsung SGH-e315
Samsung DLP HL-P5663W 56" TV Logo
302 people viewed this question
Jerry Greenberg
Jerry Greenberg
