Question about Samsung Digimax S630 Digital Camera
Lence did not move
  1. have purchased samsung Digital camera model no S630. in 2007 It is fall to my hand and damaged now i want to know what problem with this camera and whers tha service in India (MUMBAI)
    Master:
  • 383 Answers
If you try getting it serviced from the company service centre then its gonna cost you a bomb ...... try getting it repaired through a local repairman ,..... check out the listing on this site for one
Posted on Oct 18, 2008
Samsung pl90 lence stuck open
This usually occurs when the camera has been dropped or other form of shock-impact, It will more than likely require service bt a shop.
Jan 25, 2013 | Samsung PL90 Digital Camera
Not open camera lence
Ifyou hear a noise from the lens when you try to take picture or During turnon/off time then it's a lens guide pin problem OR Somehow its jammed ordamaged. It's happens when the camera pressed or drop down during turn on modeor long time not use.This problem happens because of long time no using/ Dust or Lensguide pin damaged after drop down. If the lens guide pin damage then there isno chance for repairing . Only solution is replacing the lens.For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if the camera does not start working thenyou need to visit service center for replacing the Lens or Repairing. Butbefore repairing ask service center the approx cost. if they told you toreplacing the lens then do not do that. Because a new lens & service chargecost you near about a new camera price. So best is buy a new camera. If youhave any more questions ask me I fell happy to answer your question. Thank you.
May 23, 2012 | Samsung L210 Digital Camera
Dropped the nikon d40x and the lence doesn't want to move in or out sincenikon d40x lens not working since, is it broken??
The camera body or the lens (or both) have been damaged. You could try a different lens (if available) to determine which has failed. Either way, one or the other will likely require repair (or replacement).
Contact Nikon Support:
http://imaging.nikon.com/products/imaging/support/index.htm
Sep 29, 2009 | Nikon D40x Digital Camera
Needs help
hi,if your leance could not open when you turn on camera so may be you must cheak the lence assembly breckeg , if the lence is open then servise lence unit and fix it properly,and the easy way is remove the lence unit and first remove moter from it and rolling well as possible.it must be smoth rolling between beralls of lence,then roll the moter alone well by using adapter about 5 volts,now fix it by aqurat ,you find a magic
Aug 25, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I wish to purchase 55200 zoom lence for my
Hi...
If you want to buy 55200 zoom lence for your sony camera you can buy it through online. You need to visit the ebay website this is online selling website.
www.ebay.com
Regards
PCmania
Aug 23, 2009 | Sony Cameras
I have a Canon 350d camera EF18 - 55mm Lence ,
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked good luck have a nice day!!! :) :) :)
Jul 08, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Lence will not come out.
If the lens was misaligned during the fall, that would explain an error like that. It sounds like it is not well in any case. Time for a new camera maybe... :(
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
Panasonic DMC-FX07. Dropped and died
this cam slip from my hand and the lence was open thats why lence one side down position and not working, i took this cam from saudi arabia 2 month before so pls give the suggest what i will do and where solve the problem
Nov 01, 2008 | Panasonic DMC-FX07 Digital Camera
Lence problem
Lens of this camera is not available This camera is in SWAP policy. Submit this camera in any sony service network. If warranty is valid than no cost will charge and successer model will issue you like DSC-S750
May 27, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Canon powershot falled down
You will most likely need to send the camera in for service. There really is no way to repair this problem on your own.
Since you are not out of your 1 year manufacturer's warranty, you will not yet qualify for the upgrade program, however Canon does offer deep discounts in the Canon Loyalty program for situations like yours once you are beyond the one year manufacturer's warranty.
It may be true that it would cost more to repair than to replace, and that's why the Loyalty program is great because you will at least save a bundle on getting another camera.
Hope this helps.
May 22, 2008 | Canon PowerShot A540 Digital Camera
Samsung Digimax S630 Digital Camera Logo
54 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
