Microsoft life cam 1.4
My cam is getting problem while installing. it says not enough space on hard disk or other problem, my hard disk have 93GB empty..
I need a driver Microsoft life cam 1.4.
Thank You!
Posted on Dec 03, 2008
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | Computers & Internet
Laptop runs very slow asus
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things -
1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM.
2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc.
3. Uninstall/remove unused programs, this will also free up hard disk space.
4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it.
5. Install latest Windows updates.
6. Update virus definition files and scan computer for viruses, Trojans, malware etc.
7. Clear the Internet cache for faster browsing.
8. Hard disk maintenance is required at least once a month to keep it functioning efficiently.
Run the following programs -
Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space.
Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
May 12, 2013 | ASUS Computers & Internet
My computer is not any faster even though I transterd all of my files and movies
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Apr 01, 2013 | Computers & Internet
What makes my laptop slow after booting
Feb 14, 2013 | HP Computers & Internet
Slow opration
Jan 13, 2013 | Dell Inspiron Computers & Internet
Microsoft Life Cam Vx-700 Web Cam driver for windows 7
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 06, 2013 | Microsoft Life Cam Vx-700 Webcam
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
What are the hardware requirements for foxpro?
  • Processor: Pentium-class processor
  • OS: Windows 2000 with SP3 or later, Windows XP or later, Microsoft Windows Server 2003 or later
  • Memory: 64MB of RAM min., 128MB recommended
  • Hard Disk: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Drive: CD ROM or DVD-ROM drive
  • Display: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Mouse: Microsoft Mouse or compatible pointing device
from: http://msdn.microsoft.com/en-us/vfoxpro/bb190292
Mar 02, 2011 | Microsoft Visual FoxPro 9.0 Professional...
My Microsoft office 2007 installation is not working. when i enter the product key, i get 2 options to either install now or customize. and every time i try to chose the install now option i always get the...
It means that you do not have enough unused disk space on your computer to install Microsoft Office 2007. You'll probably need to uninstall more applications but try using something like ccleaner http://www.ccleaner.com/ to help you free up disk space
Nov 29, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
