Question about Sub-Zero 632 / S
My sub-zero frig is running hot on perimeter strip
--on freezer side and I suspect shrinking size of ice cubes may be related, not sure...Help!
    Scholar:
  • 112 Answers
Usually, this either means that you have a dirty condenser unit or a faulty condenser fan motor. Check behind the top acess panel to the right and see if your condenser is clogged with dust. Also, check that the fan motor up there is going whenever the compressors are running.
Posted on Oct 18, 2008
Sub-Zero Mod 590 refrigerator: Two, I suspect, related problems. 1. Freezer, ice motor
Im sorry what is wrong? Low ice harvest or ice getting stuck before ejected? Sub zero freezer huh, does it have a cascade system? Is the ice the only issue or might it be not cooling enough to reach the thermostats set point. Also running for longer and/or more frequent could be another indication its the cooling cycle.
Feb 10, 2013 | Refrigerators
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Have sub zero side by side freezer and frig 1981. Frig is out. Does that mean the freezer also out and why is frig part out and what dial number shoud frig be on?
nope you have 2 compressor 1 for the fridge one for the freezer. is like 2 complete diferent units. we recomend the set point in number 5. is arond 37 degrees
Mar 13, 2010 | Sub-Zero 695/O Side by Side Refrigerator
I have a Sub-Zero Model 501F freezer making ice cubes
Check defrost heater that goes into drain tube. When the drain freezes ;the defrost water spills into the icemaker.
Oct 08, 2009 | Freezers
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
No ice cubes
your freezer has to be below32 degrees to make ice,can you tell me if the freezer and frig are working ok?mike
Sep 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 632 / S Logo
375 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
