Question about Fuji FinePix A340 Digital Camera
Zoom button broken
Hi On the weekend my zoom button was broken. I don't know how but it will zoom in, but not out. Not a real big problem, just annoying especially with the menus. But I have contacted FujiFilm and firstly, as I got it in Australia and do not have the warranty information, plus it has to go to Germany (from Denmark) for atleast 2 - 4 weeks, that is not worth it, as I need a camera in the next few weeks. I also can not afford a new model right now, so if anybody has some advice about whether this button is fixable and worth an effort on my part, then please let me know :) Thanks Matt
Hey, I have this camera with the same problem and the fix is easy! After taking it apart, I removed the rocker from the assembly. One of the little pins had broken off. I cut the other one off and then glued a small square block of plastic to it to create a larger attachment surface and switch surface. I then took my dremel and refined the shape of the contact points without cutting all the way through the plastic block. A couple of test fits later, the camera was back together and has not failed yet.
Posted on Oct 08, 2007
  • 215 Answers
If you can pull the camera apart (carefully) and find the zoom switch it could be that the switch itsekf has jumped the actuator. I don't know what method your camera usues but most use a rocker type switch. On the underside of this switch would be a slot which when pushed one way pushes against a small lever of piece of plastic. Let it go and the switch centres itself taking the lever with it. Push the switch the other way and it moves the lever or plastic in the opposite direction. What sometime happens is the lever or plastic somehow gets on the wrong side of this slot. So it will only push the lever in one direction. What you'd have to do is remove the top of the switch and center the lever or piece of plastic and put the camera back together. If your zoom is 2 seperate switches then one of the swiches is either faulty, the pin on the underside of the swich is broken or there is a foreign object stopping the switch from activating. You should be able to tell which one it is simply by the feel of the switch. if it's loose and wobbles around the pin would be broken. If it feels stck then maybe there's something stopping it. If it does neither of these things it could be just a faulty button switch which means you're up for a complete switch cable assembly. Good luck putting it back together. Just be patient and don't force anything. BMW
Posted on Jul 02, 2006
MY PICTURE IS TO BIG FOR THE SCREEN,I HAVE HAD THIS PROBLEM BEFORE BUT I CAN'T REMEMBER HOW I FIXED IT
Hi eastough
May be you accidentally press the zoom button on your remote control. Try press the zoom button.
Jan 09, 2015 | Televison & Video
My mitsubishi vs60607 the picture is too big for the actual screen. it's as if i set it to zoom mode but it does not have a zoom mode
Hi:
If you are using a cable box connected to the television for viewing channels, the box has a screen format button on it make sure its is not in zoom mode also. Check the box's remote for a button labeled format or Aspect or screeen.
May 17, 2011 | Mitsubishi VS-60607 TV
Google internet text is TOO small
Its a easy thing you can do it.
Press control button(Ctrl) and same time use you mouse scroll to make text size small or big.
1. Scroll forward for increase the font size.
2. Scroll backward for decrease the font size.
thanks for using Fixya.
May 16, 2011 | Computers & Internet
My screen suddenly gets real small or big big I go into view-zoom and reset constantly. How can I make it stop doing this
Well with my experience it sounds like you have one finger on the trackpad and one on the mouse button, if so the edge of your index finger on your left hand is hitting the trackpad and your other finger is moving around causing it to register the pinch zoom manuever you can use to zoom easily. Simply keep your clicking finger still and only one finger on the trackpad
Nov 17, 2009 | Acer Aspire One PC Notebook
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Broken battery cover.
I have a broken battery cover on my Olympus Camedia C-370 zoom digital camera.
Would you let me know, where I can obtain a replacement. I live in SW France.
Jan 08, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Zoom Problem
The zoom are lock due to sudden dropped , the moving parts of the zoom dislocate or broken, the zoom malfunction,you try visit some camera juck shop or repair shop same brand to replce broken parts.
Dec 23, 2007 | Olympus FE-280 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
If I take hi-res pictures with the 3040 how much can I manipulate the image on my PC to zoom in while still maintaining quality?
Digital zoom in the camera means nothing. You can't create detail that isn't there. Enlarging and sharpening on the PC can produce much better results than in-camera digital zoom - no more real detail, but a better illusion of detail by enhancing edges. You can print up to about 8x10 with the 2100 or 11x14 with the 3040, but a zoomed in 2100 8x10 will probably be a more spectacular picture than the 3040's 11x14, unless you can get equivalently close to your subject. Also, the more precise viewfinder of the 2100 can make up for the difference in resolution. With the 3040, you are more likely to need to crop to print your desired view (unless you can use the LCD), since you can't see exactly what you are going to get when using the optical viewfinder and will tend to get more periphery than you want.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
S5100 zoom out of focus
to get really close you need to set the camera to 'macro' mode a little flower icon
Sep 04, 2005 | Fuji FinePix S5000 Digital Camera
Fuji FinePix A340 Digital Camera Logo
126 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
