Question about Compaq Computers & Internet
When i turn on my computer no signal comes to my sc reen
  • youngced Oct 18, 2008
    i was told it might be the video card because i checked every thing else but the video card is biult it to the motherboard...
    Genius:
  • 1,124 Answers
Check the cables on the back
Be sure that the monitor ON
If your computer is working and No video is due a hardware issue
Check your video card
Check your memory
Check your power supply.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Let me know if you have further questions about this issue.
Posted on Oct 18, 2008
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
Vizeo plasma tv takes several time to start then picture flickers badly for a minute or two. After this, the TV comes on and functions normally until turned off. What should I look for?
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 18, 2012 | LG Televison & Video
ON RECORDING DVD FROM TAPE THE PICTURE ON MY COMPUTER SC REEN IS RUNNING JERKY.THEN WHEN THE DVD HAS COPIED THE VIDEO ON PLAYBCK THE MUSIC IS OUT OF TIME WITH THE FILM TIME ITS REALY THE CYNCRONISATION IS...
There can be a whole gambit of issues with these Dazzle devices. I hate them. Also friend have tried to copy to PC via firewire from mini DV camcorders. After a video of just a few minutes they run into lipsync problems.
For what its worth, I've managed to copy my VHS home video to DVD without issue and you may already have the equipment.
I hook up my VHS recorder with a DVD recorder which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
May 01, 2010 | Pinnacle Dazzle DVD Recorder
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
Short water fill cycle
clean the water hose sc reens
Sep 30, 2009 | Maytag MAH55FLB Front Load Washer
WHEN LAPTOP IS SWITC\HED ON..IT STAYS ON THE TRAVELMAYE LOGO WITH A THIN RED LINE TO THE RIGHT AND A THIN WHITE LINE TO THE LEFT OF SC\REEN.////////IF LAPTOP IS POWERD UP WHILST HOLDING DOWN F2 BUTTON..A...
ok..enter to the bios setup and then find "load bios setup default" and then save and restart the system.
If won't help then, verify if the hard drive is detected..if don't know how to detect hard drive, go to bios set up and find hard disk if detected. if not hard disk found then ..consult your vendor for immediate support.
melnavz
Oct 22, 2008 | Acer Computers & Internet
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Computers & Internet Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
