Question about Garden
How to fit whipper snipper line
I have a manual feed stihl whipper snipper and i need to fit new line to it. Could you please explain how to do this?
  • 6 more comments
  • Anonymous Oct 26, 2008
    Not feeding, fusing together
  • williams_mda Nov 09, 2008
    cord in snipper
  • Anonymous Jan 04, 2009
    DIAGRAM ON FITTING LINE
  • jeter_264 May 04, 2009
    I don't know how to put line in my McCulloch Whipper Snipper Model #2027?????
  • Anonymous Mar 20, 2014
    just stop working with no load
  • Anonymous Mar 23, 2014
    Where can I buy parts for fuel system , hoses & fuel filter. Googled but can't find where to buy parts. I am in Adelaide ,South Australia
  • Anonymous Mar 31, 2014
    fine plastic line caught below head of rechargable whipper snipper
  • Anonymous Apr 01, 2014
    Is there an online manual for a Morrison Whipper snipper
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Posted on Jan 05, 2012
  • Pearse Holohan May 20, 2012
    Yip, that sounds very,very familiar. I was going to have a look today for a different angle but I suppose the tried and trusted ways are always the best. Thanks !
I didn't write the Quetion, but I for one appreciate your answer, along with a lot of other people, Thank you for your time
Posted on Dec 09, 2011
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
14,691 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
