Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
Solid amber light on front amber on mother board
Ok Cross71 maybe you can help me out, I recieved advice to purchase a new moterboard. I did so and installed it. I know little about this kind of stuff so i just installed it the same way it was on the old motherboard. turned it on and still have the same problem (Amber light on front amber on motherboard) So i recieved advice to check power supply by running a jumper, Did so and I am lost from here because i do not know what the hard drive is. This was supposed to kick on when i ran the jumper. How do I know.
  • 1 more comment
  • jmandkim Oct 19, 2008
    Thanks for advice I got one beep after putting in sound card ,when I shut unit down
    And, I got one long beep after installing RAM when I shut unit down
    any advice from here?
    jmandkim
  • jmandkim Oct 21, 2008
    No luck I already did all the help files. That is why I contacted you. I bought a refurbished Mother board. It was months ago so no returning it now. I got pissed because i installed it and the same amber light appeared. Maybe board is bad. I wish I knew. I wish you knew. I know not where to go from here. How do you tell if your processor is bad? When I plug into attachments I have no monitor. keyboard. and mouse.
    PS. no lights on back with my model if there is I see none amber light on motherboard is solid amber when I connect power.
    Genius:
  • Dell Master
  • 1,056 Answers
Ok, well this is going to be a multi step troubleshooting.
Also, anytime you are working on the inside of the computer, do unplug the power cord, and wait for the little light you see on the motherboard to go out (little amber light).
Since you are getting an amber light, your control switch is connected. This is good.
First, remove the RAM (memory, looks like sticks of gum, pop the 2 levers down to pop them out) set them on the side.
Remove any cards installed (video, sound/audio), set to the side.
Go through the system, and make sure that all the plug in wire are seated correctly (plugged in, and all the way down)
Hook up the power, and turn on, listen for any beeps (wite down the sequence if there are (like 2 long, 1 short etc))).
Then one at a time, reinstall cards (power off, put in video) power on.
Leave the RAM for last.
When you do the RAM, if you have multiple sticks, do one, take it out, do the other, then both.
We are most interested in beep or flash codes (some models will have different lights on the back of the unit.
Once you have gone through doing the step at a time, let me know what the results are, and we'll go from there.
I have seen these where an item might not have been completely seated (plugged in) and give the same thing you are reporting.
But they are extremely limited in thier ability to tell you what the problem is. That's why we have to do a step at a time.
I know it's frustrating, but that's how these beasts can be at times. I go through it every day.
Posted on Oct 18, 2008
  • Coss Oct 19, 2008
    Here's the list of diagnostic codes for a 4300.
    http://support.dell.com/support/edocs/sy...
    If you also notice, it has the codes for the 4 lights on the back of the unit.
    The single beep would make sense since you had everything out.
    Now you said you replaced the board, where did you get it from?
    I have had it happen before that Dell sent me a replacement board, and it was DOA when I got it. They were very good about sending me a replacement once I contacted them (they just ask that you do it within 30 days).
    So put everything back in, make sure it is seated correctly, power it up. Listen for codes, and watch the lights on the back of it, and we can go from there.
    I know situations like this are extremely frustrating. I have over 600 Dell workstations I take care of, and I've had days that I was sorry I got out of bed. But over all, they have been running fault free for over 5 years, so I really don't have any major complaints against them.
  • Coss Oct 21, 2008
    I have to check some things. Hold and I will get you the info ASAP
I have no power but i do have an amber light on the motherboard. there is nothing else on. It's a solid light, not blinking. what do I do?
New mother board. The power section of that board probably has some capacitors that look swollen or leaking a brown substance.
Oct 22, 2013 | Dell Optiplex 755 Minitower Desktop...
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
Amber light solid. Replaced the power supply ad the cmos battery. removed the memory and reconnected. Plugged back in and I hear the fan running kind of loud (louder than before) Still solid amber light
most times i have seen amber light, if it is where the pwr light is on front of tower means ur mother board might be fried. check capacitors one by one and make sure none are extended or leaking. dell has had this issue before when they sent out a bad batch of capacitors. may last it job was mostly issues with this. good luck.
Dec 11, 2009 | Dell OptiPlex GX520 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Mar 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
take the PSU (Power Supply Unit) from a known working computer, preferable to be the same model and test with it. when you do so make sure you disconnect any peripherals e.g ( Printer, CD-ROM, Floppy).
Look closely at the memory bay for any bent pins, and test with one memory at the time.
Let me know if this is still an issue.
Regards
Dec 23, 2008 | Dell OptiPlex GX280 PC Desktop
Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Dec 15, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
2,465 people viewed this question
Alun Cox
