Question about Proscan 26LB30QD 26 in. LCD HDTV
DVD player won't play
Setup all cables correctly, TV works very well. But it won't play any DVDs. Had a new one, just out of the box, and all DVD play is distorted. Any ideas?
  • 8 more comments
  • Anonymous Feb 13, 2009
    We just purchased this t.v. and the dvd has only worked a few times. It does not matter if you put dvd in before pushing imput and going to dvd or after.I would like a proscan phone #. Sears would charge to take it back and they say they aren't going to care them anymore.
  • msmuff Feb 14, 2009
    had tv for 7 days....dvd worked one time. now when i put it in it just makes some squeaky noise and then the no disc message comes up
  • Anonymous Feb 19, 2009
    We just bought one from circuit city. On day 2 we tried to play a dvd, inserted the disc and no reponse. On top of that, the dvd will not eject. The screan just says no signal. However, the tv portion work fine. Of course circuit city says no returns and gives a phone number to call. So far no response after a week!
  • angillady76 Feb 19, 2009
    Started having problems the day I brought it home. Couldn't even insert a DVD because it was as if something was already in there. Contacted GE Warranty Co. which I purchased through Circuit City and the repair service has had my TV for almost 2 weeks now. He said a new DVD player would have to be ordered if he could find it. Still waiting....
  • Anonymous Feb 24, 2009
    Purchased the tv, got home, set it up and DVD player did not work. Could not return to Circuit City because they are liquidating and not accepting returns.
  • Anonymous Mar 01, 2009
    same works great but dvd just keeps saying no signal. I guess this is what I get for buying from a store going out of business!
  • Vkuriako Mar 10, 2009
    The picture quality while connecting to
    dvd player is not clear.
  • Anonymous Apr 09, 2009
    Same problem, everything worked fine for a week then the DVD player just says no signal. One of my favorite DVD's is in there! Please help!
    DVD Player says no signal after only a week!
  • Anonymous Mar 26, 2014
    this only happens while playing dvds
Advice to be sure label faces away from front (shiny side toward front) is correct. Also, before inserting DVD push the INPUT button on the control until "DVD" shows. To return to TV you will have to use the INPUT button again to re-set.
Posted on Jan 25, 2009
Make sure you have inserted the correctly; the label faces away from the TV/DVD player.
Posted on Dec 10, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
Dvd will not play on tv
If the cables have been installed correctly with matching color codes and your TV has been set for DVD player input, you should see something. Try swapping players to find out whether the old one works. If so, there may be something wrong with your new player.
Dec 15, 2013 | Craig Televison & Video
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Does the JVC AV-56P776 have any kind of lock out on it went thru setup it plays dvd's but not regular tv
if plays DVDs via rear connections what have you got hooked to it for regular tv reception? Hooked to the coax fitting, using antenna or cable or sat with a box or not?
Good news is if it works with DVD set is likely ok and you have some other issue----just need some more information to decide what that issue is.
May 02, 2012 | JVC Televison & Video
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung DVD-VR300 - cannot get VCR or DVD to play
cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
Jan 31, 2009 | Samsung DVD-VR300 DVD Recorder/VCR
Proscan 26LB30QD 26 in. LCD HDTV Logo
662 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
