Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 3300 dryer not heating
Hi guys i have a problem with my dryer not heating. i have looked at the switch in the back and it is fine. i have checked and rechecked the vent system and it is clean. i looked at the heating elements and they look clean. The dryer turns on and works just like it should but not drying the clothes. any suggestions on what to do. thanks
  • jjmontanez1 Oct 18, 2008
    well i can rule the lint and vent out because that things is clean as can be. i will check the element for continuity and where is the thermostat located? on the element it has two red wires connected on the side of the element. is this the spot to check for continuity?
  • jjmontanez1 Oct 22, 2008
    i will look into those things and report my findings. thank you
  • 550 Answers
With the dryer unplugged 220v is not fun
with a meter, and first disconnecting cables to each component and reconnecting them after the test is complete
check the continuity of the element, it may have burned out
check continuity of the thermostats on the heater housing and fan housing,
check the interior of the fan body for sox and lint
not a solution, yet
Posted on Oct 18, 2008
  • AlmostBob
    AlmostBob Oct 21, 2008
    yes, disconnect one cable going to each device, so that other parts of the circuit dont affect the meter, then stick an ohmmeter across each device
    thermostats vary in location, they are on fan housing, exhaust duct, heater housing, fan body, in different models
    look for objects similar in appearance to
    or some have 3 cables, some 2
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Gas dryer will heat but won't dry clothing
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Dryers
The dryer is taking 2-3 full cycles to completely dry the clothes. I have already unplugged the dryer, checked the hose, completely cleaned it of any dirt that was clogged a little. Also used the vaccum...
if you have heat in the dryer you have a blockage somewhere in the dryer or the vent line,how long is the vent line?also try removing the vent line from the back of the dryer and run it to see if it dries,i had a guy tell me he cleaned the vent line,i stuck a leaf blower in the vent line and blew out a birds nest.also check the outside duct,if there's a cage or screen on it remove it and keep it off and then blow out the line. also the duct that the lint filter slides into should be removed and cleaned.send the model number so i can look up your machine,if it's gas you could have bad gas coils,they work fine until they heat up like 15 to 30 minutes then no heat until they cool down and then they will work for a few minutes and stop again,send model number off of the dryer,open the door and look around the opening,you should see a tag with the model and serial number.
Mar 26, 2011 | Dryers
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Dryer no longer heats. Checked continuity on the
check continuity of the thermal fuse,the cycling switch,the hi-limit switch any of these that are open will stop heating all are on or near the element or air flow path to the vent
Jan 27, 2010 | Kenmore 64902 Electric Dryer
Kenmore 88752 - Dryer won't heat
We had the same problem and I pulled the unit out and discovered the dryer lint vent pipe was kinked inside the wall and full of water. It took be a full day of work but I ran a new vent pipe up into the attic and up to a static vent and now the dryer works great.
We had a service guy from Sears come out and he tested the heater strips and said they were fine and suggested I work on clearning the lint vent pipe
It worked great.
M
Mar 18, 2009 | Kenmore 88752 Top Load Stacked Washer /...
LGB6200PQ0 whirlpool dryer
HI thanks for the question. the problem ie more than likely the hi- limit thermostat., located on the heater box at the top. check this part. and the reason for part failure is dirty venting, clean all venting. replace hi- limit thermo. thanks the appliance doc please rate my answer, thanks.
Oct 11, 2008 | Dryers
No heat
The most common cause of no heat to an otherwise functioning dryer is failure of the thermal cutout.
As well as the electric line fuses in the circuit there are devices that look like this 13889aa.jpg or this 284f4e0.jpg screwed to the exhaust air duct with wires to the terminals
, inside the dryer. If there is a lint blockage in the duct or fan or outside vent hood, the air tempoerature rises and melts out this thermal cutout (also thermal fuse, heat protector, heat cutout & any other names different makers use) before causing a fire.
Test with an ohmmeter or battery and lamp bulb, conducts good, no conducts fail-replace.
Despite the number of models of dryer there are only a few thermal fuses, and the local parts guy WILL have the blown one on the shelf, as GE if not as roper part.
Whil the dryer case is opened is a good time to vacuum out the exhaust vents, fan impeller, and vent hood. ounce of prevention and all that
Jul 26, 2008 | Roper REX4634KQ Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
1,010 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
