Question about Hoover Vacuums
How do you change a belt on a hoover vacuum machine
    Sergeant:
  • 352 Answers
Hi jp.
flip unit over, take out screws that hold bottom plate on. the belt and beater brush should lift out of the craddle. there may be retention clip on some models, replace belt and put bottom back on.
anaanymous
Posted on Oct 18, 2008
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Belt repalcement
Here is a link that will explain with illustrations how to change belt. You will see 2 links. Click them and use the link that is closest to your machine.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 30, 2010 | Hoover U8130 V2 Vacuum
Does not vacum
You may have a broken or stretched belt. The machine could also be clogged. Here is a link that will take you to a site that will show you how to open up your vacuum to look for clogs and to change belt.
Hope this helps.
Jan 29, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
Hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
My brushes stopped spinning. what do i do?
Easy enough reference your owners manual and find out the replacement belts, from there if you provide us with the belts part numbers or model of you machine i can have them ordered for you, submit your info here: Vacuum parts
good luck
Sep 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
