Question about Vivitar MAGNACAM Binocular
My equipment comes with a cd and cable but it jusgt wont install on my pc/ How do you set this up?
Vivitar was owned by Syntax-Brillain which went bankrupt July 2008. Sakar International has taken over. Solutions to the problems on the Vivitar 10x25 Binocular Camera will not be address until Februrary 2009. Contact www.sakar.com or 1-877-397-8200 for further details. I glad to hear that at least some customers got the USB cable for the device and some drivers were working and some low-quality images were coming out of the camera. The best solution is not to buy the camera without a demonstration, etc.
Posted on Oct 22, 2008
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Hard drive and cd drive not recognized
In this case if your laptop runs occasionally sometimes not. The prom the is the faulty cable which is connected to the HDD and CD drive. Try to replace the connector cable with the other one. Check also the BIOS setting of the HDD and CD drive.
Regards
nicole
Oct 02, 2009 | Computers & Internet
I have brought a new computer that dosnt have a cd rom. I have tried putting in two different cd-roms but they wont show up on my computer. i have tried downloading drivers to help but it still wont work.
Hello !
Your CD-ROM should have at least two cables connected to it: a power cable and IDE cable that should also be connected to your motherboard. Disconnect and reconnect the cables and be certain that they are snug.
Some computers will also have a small third cable used to interface the CD-ROM with the sound card. If the audio for your CD audio CDs is not working properly verify that this cable is not disconnected from the back of the CD-ROM.
Hope this helps.
Sep 19, 2009 | Dell OptiPlex GX270 PC Desktop
Pc wont play cd or dvd
On many CD-Roms, or burners, there is a plug on the back that is for Digital Audio. It is a rectangular shaped plug. Some PC's require that a cable is attached from the back of the burner, to either the on-board audio (on the motherboard), or to the sound card that may be installed. If you have any further questions, just let me know :)
Mar 06, 2009 | HP Pavilion M9040N Elite Desktop PC
No CD need to set up Linksys Wireless G Router
Router setup
You do not have to use the cd. Follow these instructions:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | Linksys Wireless-G WRT54GS Router...
Cd rom wont play discs
If other disks work the installation disk might have a problem. Try using Windows Explorer to check the folder structure on the CD.
Most routers can be configured by connecting a network cable between your computer and one of the network cable outputs of the router ... (but not the one that is used to connect the router to the modem). Check your router manual or check on-line at the (router) manufacturer site to see which numbers have to be typed into a browser to access the router this way and set it up. It often is something like 192.168.2.0 or ending in 1 with default user name and password "admin"
Jul 20, 2008 | HP Pavilion N5415 Notebook
I have a wireless g pci adapter and it is installed on a computer running windows 2000 server. It is supposed to receive the signal from the wireless router wrt54g. It does not find the signal but somehow...
Hi, did you run the CD before you connected the adapter? I know the box says 'easy, no set-up' but there usually is a CD that needs to be run BEFORE connecting the device. If thats done, try bringing up the 'connect to a network' interface, selecting your network and click connect. If you have set up a wireless security password, enter it and click connect. The network cable unplugged is normal when you are running a wireless setup. I hope this is of some help.
Apr 27, 2008 | Computers & Internet
No Internet light, but an Ethernet light that blinks?
for westell 6100 modem usb driver installation follow the steps for windows xp
-close all programs
-unplug usb cable from the pc
-insert installation cd from verizon
-plug usb cable back to pc
-wizard will pop up found new hardware
-click next then follow instructions
-select usb connection on the installation
Dec 14, 2007 | Westell Wirespeed LiteLine 6100...
Is the 2400 Toast ???
Two main reasons why this things happen, first.. there's an error with your hardware. If you know how to diasassemble your pc, then do it. Cleaning your machine will make it work. If it doesn't, repair the operating system with your windows installer cd. Be sure to clean your cd rom or you might as well borrow or buy a new cd rom so that the installation will run smoothly
Dec 05, 2007 | Dell Dimension 2400 PC Desktop
Vivitar MAGNACAM Binocular Logo
Top Vivitar Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
