Question about Logitech Computers & Internet
Caps Beep on and off driving me mad
Hello I have a Mod Y-BF38 and I dont know how but something must have been activated accidently on the keyboard as when the Caps Lock is keyed on and off it makes a beep noise which drives us mad.
Can anyone help Please! :)
  • dafraf Oct 18, 2008
    Thank you, and my ears thank you as well, Fantastic !!!!!!!
    President:
  • 1,901 Answers
Hold your NUMLOCK key down for 5 seconds until you hear a beep. Problem solved!
Posted on Oct 18, 2008
My cap lock key beeps every time I turn it off and on.
Help please.
Posted on Sep 02, 2009
CAPS LOCK STATUS DOES NOT APPEAR ON THE SCREEN OR ON KEY BOARD
I don't know how to make this status appear, however here's a way around it.
Go to Control Panel. Ease of Access Center > Make the keyboard easier to use. Check the box next to "Turn on Toggle Keys. Hear a tone when you press CAPS LOCK, NUM LOCK, or SCROLL LOCK".
From now on, you're going to hear a beep whenever you press CAPS LOCK key on or off, the beep is slightly different depending on whether you press it on or off. Slightly higher pitch when you press the CAPS LOCK to stay on.
Oct 08, 2014 | Logitech Computers & Internet
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
How do you know if the CAPS LOCK button has been activated: do not see any indicator ?
I have the same keyboard and it does not have a caps lock lamp.
The only way of knowing if the caps lock is on is to type something in a text window although some websites will tell you if your caps lock is on as this can cause errors when entering passwords etc.
Jan 14, 2011 | Logitech Cordless Desktop MX3200 Laser...
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
I have a Logitech 300 keyboard and do not know which key shuts my computer down. I have accidently hit one which does this whilst I was touch typing and do not know which key I accidently hit.
Hello!
I try to find something, and I am glad if can help with this. I think that is key for shut down, right on top.
Try this document in PDF format.
http://www.logitech.com/repository/1408/pdf/13049.1.0.pdf
Nov 02, 2009 | Logitech LX 300 (9674270403) Keyboard
Lazy finger causing keyboard to lock in all caps??
Does it happen with everything you type or just in particular programs? If it happens in Microsoft word 2003 highlight the area where the all caps is happening then go to Format, Font. Under the Font tab there is a section called Effects, in this section there is an All caps option, uncheck it.
If it types all caps everywhere there could be a short in your keyboard. You can solve this by taking your keyboard apart using a multimeter to find the short and reconnecting with solder or electrical tape. Getting a new keyboard or talking to tech support can also help.
Dec 08, 2008 | HP D8597A Keyboard
PVCLE266M_L Error Ram
One beep is good. How many beeps is important. Beep codes are listed by BIOS manufacturer. Also in the basic setup deselect ECC if the RAM is not ECC (Error checking mostly used by server environments -private users rarely care). Remove and reseat RAM one at a time making sure that you have the correct RAM -Kingston is good but make right and wrong RAM for your computer). If there is no display then you must try to enter setup. Again -the beep codes are important. At the keyboard press Caps Lock and see if the corresponding light goes on at keyboard. If it does go on then look at monitor to see if the status light is yellow or green. Yellow means no signal from mobo. If the keyboard has no lights then there is no POST from motherboard (mobo). If there is more than one beep them there is RAM defect or video defect. Repost with results if you need more help.
Oct 14, 2008 | Computers & Internet
NO display.1 beep followed by 4 beeps.
try remove and clean the memory and the insert it again.. if this not solve you need to replace it.
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 13, 2008 | HP Compaq Presario V2000 Notebook
Acer ast180
The beeps that you are hearing are messages created by the POST (Power On Self Test) to indicate that something is wrong. If you know your motherboard type it is possible to find the documentation explaining what 3 beeps mean.
Because we don't know the motherboard type (At least for now) let's use the common sense.  Did you verify that the power supply is properly connected to the drive?  Can you confirm that removing the second Hard drive it boot again ok? In some type of BIOS 3 beeps means memory problem. By accident did you touch the memory? Are all the ribbon cables well plugged in?
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
271 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
