Question about Acer Aspire 3680 Laptop
Boot problem I had my laptop in a case, and someone went to pick up the case, and dropped it on the counter. now it will not boot up at all, and the power light blinks 8 times, then i have nothing
  • Acer Master
  • 5,568 Answers
You would need to note whether the 8 blinks are in a specific order; this is probably equivalent to beep codes and the spacing (grouping) of the beeps/blinks may tell you what problem you are having (other than having clumsy buddies).
Check to see if they are grouped in some recognizable manner such as 3-3-2 and then you would have to check with Acer to decode the sequence. Depending on whose BIOS is installed in your model, the 8 blinks equally spaced may be valid too and tell you the nature of the problem..
An example of the 'beep' codes can be seen here, midway down the page:
http://www.techsupportforum.com/hardware-support/laptop-support/163870-acer-aspire-5100-three-beeps-no-screen-boot.html
Posted on Oct 24, 2008
Golf 2 rev counter stopped working
try he alternator the rev counter should be picked up from the w terminal on the alternator
Nov 27, 2011 | Cars & Trucks
I dropped my laptop, it said it is repairing disk errors... it said itll take an hour but it hasv taken over 10 hours because i left itvover night! what do i do?
if it seam that it will not end..just restart and try to boot the operation system..and let me knoiw what it says..probably it do not see the hdd and this is the issue ..if it asks to insert or select the boot device //it means it do not see it and we have to see if its a setting or a physical fault ..But there is a big chance that iot will just pick it up and go ..
Jan 17, 2011 | Dell Inspiron 1525 Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
I have a HP laptop and it's trying to boot using the 'Attempting to Boot Network' status. I went into the BIOS and my HD is set first. Reboot, same status message. I went into the BIOS again, disabled the...
Sounds like the laptop is not detecting the hard drive. Remove the hard drive ad plug it back in again. It usually solves that problem UNLESS the hard drive has crashed and cannot be picked up again.
Jul 06, 2009 | Computers & Internet
Apple iPhone Smartphone
telecharger and installer this program i phone PC Suite in this set
http://iphonefreakz.com/2008/08/20/iphone-pc-suite-compatible-with-firmware-20/
and pronsh your phone with one usb verifier if your phone
is connected in the programe
Click in system. Fix startup…..
Jan 23, 2009 | Apple iPhone Smartphone
Spare Tire Cable will not drop while turning the crank
it requires the weight of the spare to make the cable unwind
turning counter clockwise to let the tire down is correct but it requires weight to make the lock clutch to disengage and if it does so the cable may become entangled in the casing and surrounds
you should be able to access the winch unit and remove it from the vehicle to work on it
Nov 15, 2017 | 2005 Dodge Grand Caravan
HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Nov 15, 2007 | HP Compaq nc6320 Notebook
Sony Vaio cannot start up
Hi, This sounds as if a sizable/critical portion of your OS is not loading properly if you cannot even boot to Safe Mode or any other choice. Probably your best course of action would be to reinstall your OS doing a Repair and not a clean fresh install. Your PC might have recovery CDs for this purpose. Hope this be of some idea/help. Post back how things went or should you need further information. Good luck and kind regards.
Sep 09, 2007 | Sony VAIO (PCWA-A200)
Acer Aspire 3680 Laptop Logo
255 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
