Question about Samsung YP-T10 Digital Media Player
Samsung YP-T10 "Device Wont Start. (Code 10)" Win XP
Hey all, I get the "Device Wont Start (Code 10) error. It worked before on my pc, when I went to charge it, It wouldnt sync properly.. looked around for the answer.. cant find one. Please Help
    Sergeant:
  • 213 Answers
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
  • do this
  • go to my computer> properties>hardware > device manager >USB>right click on it> update driver>
    then1
    1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
    your problem will now soved
Posted on Oct 21, 2008
My samsung YP-T10 4GB won't show up on my laptop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This MP3 player is a flash player so your PC should recognise it automatically. If this is not happening, i would advise downloading an MTP Porting Kit from www.microsoft.com.
Please also access My Computer, Right Click, select Properties, Hardware and then Device Manager. Find the MP3 in the list, right click, Properties and select Update Driver.
If this does not work, try the troubleshooting wizard and try to get an error code. If you get an error code, searching the knowledge base on the Microsoft website will advise what this means.
Jul 16, 2009 | Samsung Audio Players & Recorders
Samsung mp3 players YP-T10, I lost the usb charger!
I lost mine as well and after searching the web I found a web site called www.eforcity.com which had the usb chargers. It said it was for the Samsung YP-K3, bu that it is compatible with the T10. It was only $5.99. I am hoping it works when I get it. Good luck!
Apr 08, 2009 | Samsung YP-T10 Digital Media Player
YP T10 WONT SWITCH ON!!
on the back...push th reset button...easy..
Feb 18, 2009 | Samsung YP-T10 Digital Media Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Unable to transfer videos to my YP T10
try windows media player 10 or 11 version.may i know what type of video extension.
Oct 23, 2008 | Samsung YP-T10 Digital Media Player
Apple Mac driver for Samsung YP-T10JAB/XSA
this device uses mtp protocol. Mtp protocol supported from all OS (mac, linux, win etc..) check these links:
http://en.wikipedia.org/wiki/Media_Transfer_Protocol
http://www.fixya.com/support/t429679-device_drivers_samsung_yp_t9jab_xac_mp3
Sep 28, 2008 | Samsung YP-T10 Digital Media Player
Nothing pop's in my screen comp,
I think I got it guys. forget WMP 9,. 10 , 11... I run win xp service pack 2 and could not install the samsung yp-u3 player. I kept having it found as a new hardware {portable device} but as we all know this software has no drivers, and the windows update produces MTP device error. Resulting in you not being able to see your player in XP. Well go to windows update site and search for a file called "mtppk12.exe" I'm pretty sure once you install that file and reboot, you will no longer have MTP device errors. However, I installed this at the same time i installed windows media player SDK. So maybe both files are required. Finally after 2 days of troubleshooting i got mine to work.
Jul 28, 2008 | Samsung YP-U3 MP3 Player
Samsung T10 Mp3 player to be recognised by pc
Heres how I solved this problem
- I was running XP SP2 with WMP10
(Windows Media Player 10)
- Windows will not recognise the T10 unless it has the right MTP (Media transfer Proticol) drivers. This is the little yellow flag you may see on the task bar adter Windows detects the device and trys to install the driver. The drivers are only found in WMP11. Therefore unless you are running WMP 11 your T10 won't sinc or be recognised.
- The Samsung software wont help- so don't bother even installing it as WMP11 has the drivers and does everything the Samsung software does + more.
- I tried to download and install WMP11 directly from the microsoft website but my PC failed the authentcation so I saved the file to my HD instead.
-I then unpacked the WMP11.exe file using WinRAR which i downloaded for free from http://www.download.com/WinRAR/3000-2250_4-10745708.html.
- I individually ran the WMP11 install file and then all of the other unpacked files by double clicking on them (it takes some time). This installed WMP 11
- I then shut down the PC, plugged in My T10 and WMP/windows recognised the T10!
I had a friend who alos did the above but had a couple of problems- he uninstalled WMP10, Installed WMP11 using the WinRAR method above and it didn't work. After uninstalling WMP11 and then reinstalling it again using the WinRAR to un pack it it finally worked after a couple of re boots.
Note: Prior to using the above method i googled and tried several other ways to get the T10 recognised and none worked. From what I can tell you Need WMP 11
Hope this helps
Jun 12, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-T10 Digital Media Player Logo
258 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
