Question about Electronics - Others
Thanks but i need more help
Thanks for trying to help me but your advice didnt work. The problem now is that neither the original remote control (tv silvania) nor the sentry RMC10 remote control work. It's really weird. the sentry RMC10 work when i interchange to DVD and Cable functions but as soon as i try to control my tv, the remote control becomes useless. As i told you before the only way i can turn on and off my tv is when i plug and unplug it. Besides that on the screen appear strange numbers and words that i've never seen.
    Genius:
  • 1,124 Answers
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Posted on Oct 18, 2008
LIKE A REMOTE FOR DAENYX TV,WHERE TO BUY Thanks
"Call 1.800.237.8289, and ask for PARTS SOURCE. Have your TV information ready, and they can get you the OEM remote. Other than that, any Sony or Logitec programmable remote should work"
Apr 04, 2011 | Electronics - Others
TV not working
The red light flashing is an error code. Count the number of flashes before a long pause.
Mar 22, 2010 | Samsung Electronics - Others
Need Device Code for Boston Acoustics DT6000 remote to program volume on my universal remote
Hey Mike,
I have the same system and my BA remote control just died. Did you ever find the code for the DT6000 to use with a universal remote?
Thanks for your help,
luis.castellanos@gmail.com
Nov 15, 2009 | Electronics - Others
I have got a new sky+box and remote. can i use a previous sky remote with my new sky+box and if so, how do i sync it? thanks.
you can only use a previous remote if it is a sky+ remote, original sky remotes will not work with the sky+ box. vice versa
Nov 13, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
Apr 09, 2009 | Panasonic Electronics - Others
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
Can't use menu function on remote control for pioneer krl-32v TV
ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
Mar 14, 2009 | Electronics - Others
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
No Remote for Acesonic DGX-106
This link will take you to the manufacturer. You should be able to get the factory remote here. Send them an email.
http://www.acesonic.com/playersitem.php?id=1
Hope this helps. Steve
Dec 19, 2008 | Electronics - Others
Remote control programming
select (interactive) go to option 5 (sky customer services) go to option 5 (remote set up ) then follow the on screen instructions
Jan 21, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Electronics - Others Logo
109 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
