Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson, sportster
I can't get any spark
  • 1 more comment
  • jamie Jan 31, 2009
    weak and intermitant spark while cold
  • Brad Hurt
    Brad Hurt May 11, 2010
    NEED MORE INFO
  • beer71fx May 11, 2010
    what year? is it stock? Has it been idle for a long time?
  • 216 Answers
That can be cause by a bad coil, or regulator, a bad ignition module or fuse, or a bad connection to any of the above. A faulty crank position or bank angle sensor as well. Do you have a multimeter ? You will need one to trace the problem, but first check all your fuses and connections starting at the battery
Posted on Oct 18, 2008
Spark plug gap on 2004 Harley Davidson 883 sporster
Hi, Anonymous the correct spark plug for your Harley-Davidson model is HD 6R12 and gapped at .040". With a dab of Anti-Seize on the threads install using an applied torque of 15 ft lbs. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Harley Davidson Sportster Evolution Spark Plugs Replacement
Harley Davidson 2005 Sportster Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Sep 21, 2017 | 2004 Harley Davidson XL 883 Sportster
Harley Davidson XL 883 Sportster no spark
Hi, Eric and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
99 Harley Davidson sportster 883 no spark issue
Jun 30, 2017 | Harley Davidson XL 883 Sportster...
Harley davidson xlh sportster 883 backfires
Hi Anonymous, here is a short list of could be's: bad spark plug, plug wires, ignition coil, ignition module, low battery voltage, loose cable and wire connections, circuit breakers, bad intake and or exhaust gaskets. For further possible clues visit website below: Harley Davidson Sportster error codes and how to access them
Good luck
Apr 03, 2014 | Harley Davidson XLH Sportster 883 Hugger...
I need spark plugs
http://www.jpcycles.com/2009-harley-davidson-sportster-1200-nightster-xl1200n/spark-plugs/exact-fit
Jan 18, 2014 | 2009 Harley Davidson XL 1200N Sportster...
Why is my Harley Davidson 883 Sportster miss
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Sep 07, 2013 | Harley Davidson Motorcycles
2003 harley 1200 sportster won't start when warm tuns over no spark just changed coil no difference starts right away when cold
Hi Curtis, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
May 06, 2012 | 2003 Harley Davidson XL 1200 C Sportster...
2000 Harley Sportster 1200S has no spark
Hi Mike, please be aware that this question has already been asked and answered. Thank you.
Apr 15, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
Spark plug wiring on Harley Davidson 1200s sportster
Hi Brianpardy, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Apr 09, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
Spark plug
The proper air gap is .032 to .036 depending on spark plug brand.
Nov 20, 2008 | 2005 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
242 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
