Question about Sanyo Lands Phones
WE purchased a CLT-D6620 Sanyo phone. I was tinkering with the settings and somehow I selected something that inactivates the digital display so it went blank. I unplugged the phone and took the battery out of the phone for two hours and it still is not working....help... any suggestions? I can not reset the phone to default, since I can not see what panel I am trying to get to with the default screen?
  • 201 Answers
SOURCE: No dispaly on screen.
Three possibilities. 1) The LCD screen is cracked from a fall or hit etc.. It can be visible or a small crack hidden on and edge or corner, only visible after taking out the display. 2) The phone was exposed to moisture or high humidity long enough for corrosion to start. This could have happened many months ago. The corrosion has finally effected the LCD. If you're up to disassembling the phone you can clean the LCD connector with rubbing alcohol and a tooth brush as well as clean the LCD cable itself with a pencil eraser. Typically the LCD is held in with a little 2-color connector that you open with a tiny screwdriver or other tool by carefully prying off each side of the connector a little bit. (1-2mm) when you are done just slide the lcd connector in all the way and push the connector back in. 3) It's unlikely but the LCD can just stop working. It's not worth paying $30 to $50 for a new one. Just replace the phone.
Posted on Jul 12, 2007
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: Problem with ATT cordless phone set (3 phones)
i just replugged the phone jack in again,, made sure it was in right,, that solved my problem,, hope this helps,, pretty simple hey,, oh well, i hope it is as simple for you..
Posted on Jan 29, 2008
GrinningFool
  • 625 Answers
SOURCE: my sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Posted on Mar 23, 2008
  • 205 Answers
SOURCE: phone cannot find base
complite opening phone re connection remove safty try it
Posted on Jul 09, 2009
Sanyo cordless model no CLT-79 a peep sound comes when i press the call bottom
Sir, I've lost hand set of SANYO CORDLESS TELEPHONE and modle no. is CLT-79, How will i get the same ? pl. hlep.
Oct 28, 2010 | Sanyo Cell Phones
I want the owner manuel for sanyo clt 9905
Here is the link to download a free vrsion of the owners manual.
http://safemanuals.com/user-guide-instructions-owner-manual/SANYO/CLT-9905-_E
you will need to look at the page carefully and click where it says download the complete user guide on the right side of the page.
Then fill out a 1 minute rating of the product and the link to download your manual will be given.
Oct 30, 2009 | Sanyo Lands Phones
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Need to change lanuage from spanlish to english on sanyo mm7500 cell phone
You can choose to display your Sprint PCS Phone’s
onscreen menus in English or in Spanish.
To assign a language for the phone’s display:
1. Press to access the main menu.
2. Select Settings.
3. Select Others( ).
4. Select Language.
5. Select English or Español.
Aug 12, 2008 | Sanyo Cell Phones
Sanyo CLT 947
Two solutions. Replacement rubber key pad membrane or re-apply conductive coating.
1) Call Sanyo and see if they have a replacement rubber membrane keypad for your model of telephone. (I replaced the keypad membrane on my Sanyo CLT-2430 cordless phone). In Canada, the Sanyo telephone number is: (905) 760-9944. Their web page is: sanyocanada.com.
2) A rubber keypad repair kit is available from MG Chemicals. Rubber Keypad Repair Kit 8339.
This kit is described on their web page: http://www.mgchemicals.com/products/8339.html
In Canada, this keypad repair kit is available from ElectroSonic. See a description of this kit at: http://www.e-sonic.com/acc/products.aspx?command=detail&partID=8339&partIDExt=281
In Canada, this keypad repair kit costs about $14.00.
Apr 22, 2008 | Sanyo CLT-A902 Cordless Phone
Digital Television
You will need to use a converter box if you want to receive digital signals from an antenna as the tuner is not the ASTC (HDTV) type. Once you get a converter or cable box you can come out of it with component video cables and go into one of the inputs in the back of the set.
Feb 26, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Flash time setting
I'm trying to find out what flash time is. I have a KXTGA 550M. In menu, initial settings, set tel line, set flash time: there it has settings 700ms-90ms. What does this affect?
Jan 19, 2008 | Lands Phones
Lands Phones Logo
67 people viewed this question
Top Sanyo Lands Phones Experts
David Burbee
David Burbee
Are you a Sanyo Lands Phone Expert? Answer questions, earn points and help others
