Question about HP Compaq Presario V2000 Notebook
MBR error OK, I'm back with my Compaq Presario V2000 MBR Error problem. I have now successfully booted using a bootable Spotmau PowerSuite CD. How do I proceed with repairing the MBR error?
    Genius:
  • 1,056 Answers
As I mentioned in your first post, it sounds like the hard drive has the problem.
Replace the hard drive.
Posted on Oct 18, 2008
My compaQ dx6120mt desktop initialising ram but not booting
when you boot does it pop up with any additional information such as "No bootable disk found" or "corrupt MBR"
If you get no bootable disk it is the HDD has failed
if you get Corrupt MBR then you need to reinstall windows
if nether of these appear and the system just hangs on the DOS start screen then it could possible be your RAM at fault
Mar 13, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
0xcooooooe error
This error may occur if the registry entries and the drivers for the mass storage controller hardware in the backup computer are not installed in Windows. Download any reliable program like I always use Reginout to fix such errors by using its Repair Registry feature. And update drivers.
Dec 10, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
How do I remove write protection on a Dell XPS 8300 desktop - MBR corrupted, write protected
MBR means your WINDOWS or YOUR HARD DISK are dead!
Reinstall WINDOWS or replace the HARD DISK!
Aug 03, 2012 | Dell Computers & Internet
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
Compaq Presario V2000 - lsasse.exe error
That little app is a major factor in the security of your system. You should boot from the XP CD and attempt to repair your current XP installation to rremedy the problem. It can lead to problems connecting to other computers on occasion, but more frequently it can cause problems accessing files on your hard disk.
May 29, 2009 | HP Compaq Presario V2000 Notebook
My CD/DVD Drive has sudenly stopped working.In the devive manager the code error is 10. The model of the computer is GM5066B and the serial no. GSG7211000075. Same problem on a Compaq Presario SR5213 with...
Things to check
1. See if the drive is identified properly in BIOS, if it is not, reseat all cables and try agian.
2. Can you boot to the drive using a bootable CD (XP CD or such) If the drive functions outside Windows, then it is a software issue. If it doesn't boot to bootable media, then you most likely have a hardware issue.
If you can boot to the CD, then try booting to the safe mode, removing the drive from device manager then remove the upper/lower filters in the registry then reboot in to the normal mode.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jan 25, 2009 | Compaq Presario 5000 PC Desktop
MBR error
MBR = Master Boot Record
It could be that you have a bad hard drive.
Yes, test the CD in another computer (just abort the install after you establish it is ok).
It could also be that your BIOS may be having a problem (the can boot from CD).
How old is the laptop?
Oct 18, 2008 | Microsoft Windows XP Home Edition
Notebook is very slow want to format
You can do that by inserting a bootable windows xp or other opetrating system. And then boot the system in CD/DVD rom drive.
However if you have a cd/DVD system recovery you can do that by booting also on that CD/DVD and then just follow the onscreen instruction.
You can download the CD utilities of your stuff here: http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
see this site for more information on how to install operating system http://support.microsoft.com/kb/316941
hope this help.
any problem arising thereto please notify me for further instruction.
Jan 16, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
