Question about Kenmore 22622 Top Load Washer
Kenmore gearcase The new gearcase finally arrived today, and thanks to your excellent instructions, the installation was a breeze. Everything seems to be working fine, hopefully there won't be any problems for a few years. Thanks again jsrock, much appreciated. billybob
  • 5,911 Answers
Glad to hear everything went well and you were able to use my instructions. The installation really isn't that difficult if you have some guidance. Not to mention, you just saved yourself a bunch in labor charges. Let me know if you need assistance in the future. Congrats!
Posted on Oct 18, 2008
Washer does everything except spin
This is most likely a failure of the plastic couplers / rubber isolator between the motor and gearcase. This assembly is designed to fail during an overload condition, but they often just wear out over time. If you are mechanically inclined, it's not a difficult repair to make.
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET---
1. Remove console
2. Remove 2 gold clips at rear of top
3. Unplug lid switch harness
4. Rotate the cabinet up a few inches at the rear and pull it straight off
5. Near the floor at the front of the machine, you'll see the pump, motor, gearcase assembly
6. Remove the 2 large metal clips that hold the motor to the gearcase (you might have to disconnect the motor wiring connectors
7. Rotate the motor / pump downward so the end of the motor facing the gearcase is pointing up / out so you can see it.
8. You should see evidence of a failed coupler... rubber and / or plastic pieces
9. Pry the broken plastic couplers off of the motor and gearcase along w/ whatever's left of the isolator (black rubber)
10. Install new parts (probably need to get these at your local appliance repair shop)
11. The tricky part is realigning the couplers and isolator so you can push everything back together. Be patient... once it's pushed back together, reinstall the large metal clips, motor wiring connectors, etc.
12. Put the cabinet back on, being careful that the rear corners are pushed inward so they engage on the base tabs
13. Install everything else in reverse order of removal
14. Plug it in and listen to her purr...
Good luck.
Jan 16, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore washing machine does everything but spin
yes that is how some parts are plus it is like a two hour job
Jan 01, 2010 | Kenmore Elite 20972
My kemore side by side is luke warm as of this morning.
Sears gives their models different numbers for example 198.215478
Look for the number so I will be on the correct model and help you better.
55c7687.jpg Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Gearcase
The following link gives step-by-step instructions on how to repalce the gearcase on a Kenmore top loading washing machine with a direct-drive transmission:
http://www.fixya.com/support/r699497-replacing_gearcase
To answer your question, "yes", you DO need to remove the agitator. That is explained in step 11 of the instructions. I hope you find this information helpful. If you require additional assistance, please let me know.
PS Any particular reason why you are wanting to remove the gearcase?
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Re: gearcase
Its hard to tell without seeing it. If the clutch is covered in oil (from the gearcase), it may be a good idea to replace it. Otherwise, you can reuse the old one. Let me know if you get to a point where you're stuck and need assistance.
PS The gearcase has specific instructions on the container that it be shipped in the UPRIGHT position. This prevents the gearcase oil from leaking out. In addition, there is a small breather hole on the top of the gearcase, that is sealed with paint prior to shipping. Don't forget to use a scribe or an awl to open this breather hole BEFORE installation.
Oct 08, 2008 | Kenmore 22622 Top Load Washer
Kenmore washer won't spin
That's a tough one, Billybob. It can either be a Gearcase problem, or a Basket Drive. Since the washer seems to be performing all other functions, I'm leaning towards your assessment of a Basket Drive. You can get the entire drive and brake assembly as one unit at searspartsidirect.com. Just type in your COMPLETE model number and look under the "Brake/Clutch/Gearcase/Motor and Pump" heading for item number 1 (part #285792). I would be prepared, however, that if that doesn't correct the problem, you may have a gearing problem with the gearcase (especially if your gearcase is leaking oil really bad). Usually when they go bad, the washer will usually exhibit symptoms of slow spins, assisted spins where you have to spin the tub by hand to get it started, or loud grinding noises. If you require instructions on how to replace the drive, let me know.
PS I would recommend you also purchase a new motor coupling if your doesn't have the steel grommet in the center (you'll thank me later if you do). That's item 13 under the same heading. Also, you will need a center post gasket (tub gasket) which listed as item number 16 (part #383727) under the "Agitator/Basket/Tub" heading, and a tub ring gasket which is item number 9 (part #3976308) under the same agitator heading. Replacing these seals will prevent potential leaks when you are done.
Oct 07, 2008 | Kenmore 22622 Top Load Washer
Phaser 8200 error message - lamps out
I was wondering if any of you have the guide with pictures on the instructions. I got to step 5 and I am stuck trying the remove the upper transport.
Thanks
nbt@tslnet.com
Jun 26, 2008 | Xerox Phaser 8200 Laser Printer
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Kenmore 22622 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
