Question about RCA P61960 61" Rear Projection Television
RCA P61960 Picture is concaved
The left and right sides of the screen normal but the middle seems to be condensed/smaller. Tried using the service menu, P0 V72, change P1 through P23. I could change the size and position, P10 and P11, but could not change it to remove the concave.
  • GhostRider57 Oct 19, 2008
    Does anyone have a diagram of where this chip is located or how the chip is labled?
  • 905 Answers
This is the conversion chip or sometimes chips that cause these effects the chip or chips are about $30 each but labor is alot more $250 -$300
Posted on Oct 18, 2008
  • jason Oct 23, 2008
    they are big IC's on a heat sink that start out with STK
    check out this site and click component cross reference then type in your stk #
    http://www.nteinc.com/
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
The picture and colors went out of focus.
Blowed Fuse there is 3 of them on the right hand side of the FBT flyback Transfomer they Look like small brown rectrangler caps But are Fuses .06amps
it will be the one in the Middle FL231
PartStore.com has them 1-866-925-7278
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Concave picture
sounds like the bulb is on its way out, they can be replaced for about 100 bucks.
Jul 25, 2009 | Philips 51PW9303 51" Rear Projection...
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture on projection screen is concave in the middle
This set does not use IC's for convergence. Most other brands do use IC's.They use individual transistors in this one and honestly I don't remember ever seeing these go bad. Normally it is the power supply that runs the convergence transistors or more commonly known as the convergence board. It gets pretty technical with this type of problem. Have a repair shop check it out for you and avoid the headache. Thanks
Jun 07, 2009 | RCA P61939 61" Rear Projection Television
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
Rca p61960 projection tv
That sounds like a Pincushion problem if you having bowing. It's probably bad caps and diodes on the deflection module. This is not an easy fix. If you know how to read a diode and you visually inspected the caps you might have some chance of fixing it yourself.
Aug 17, 2008 | RCA P61960 61" Rear Projection Television
Picture too big for screen
if anyone has this p61960 television that does not work anymore, I am looking for parts for mine and would buy, please let me know, thanks
Oct 14, 2007 | RCA P61960 61" Rear Projection Television
61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Jun 14, 2007 | RCA P61960 61" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
257 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
