Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
What does my hard drive look like
I installed a new mother board and am still getting same problem so i tested the power supply according to directions and only power supply fan is comming on where and what is my hard drive and processor
  • jmandkim Oct 18, 2008
    when i tested the power supply i had to run a jumper from the green wire to a black wire in the power supply chord the power supply fan and hard drive were supposed to come on i know the power supply fan came on but i las not sure where the hard drive was to check it
  • Coss May 11, 2010
    What is your hard drive and processor?
    The processor is on your motherboard, and it's the "brains" of the computer.
    Please explain your question, it's slightly confusing the way it is worded.
    Sergeant:
  • 352 Answers
Hi jman,
just look at the front of the pc a green light will come on if the hdd is getting juice. The harddrive looks like an old 8-track tape, I'm showing my age, ugh.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 18, 2008
When I first turn on the power supply the CPOU fan turns on for about 5 seconds. Then the entire computer will not turn on by the power switch although there are green light on the mother board and the...
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 25, 2010 | Antec Power Supplies: SP350 SmartPower 2.0...
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Installed new Mother board and cannot get the power supply to turn on computer. How can I tell if the Power supply is bad or something else is wrong?
First off is the power supply powerful enough for this new mobo? is it new, old?. Is the motherboard securely earthed either in the case or on test bench?
If you have it in a case already strip out everything leaving just the motherboard and graphic card in. Power up now.
If this works put the memory back in.
Then hard drive etc until you have everything you need installed.
If it doesn't work you should try another graphic card if you have access to one. Also make sure the graphic card is seated properly.
If none of the above works then there is a good chance you have a faulty motherboard so best to replace it.
Oct 16, 2009 | Gateway Computers & Internet
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
Dell Precision 380 won't boot
I had a similar situation with a work computer; the power supply always tested good. A wiser and more experienced computer guru ordered a new power supply. He gave it to me told me to install it, I did and was laughing the whole time. Well it in fact was the power supply. Reason, power supplies are funny like that, they may test good under ideal conditions which is a minimum load put on the unit (enough to boot your system). They are not tested with the stresses of maintaining all your fans, hard drives, mother board, video card, monitor, CD drives, mouse, and keyboard. Its when those loads are applied is when the unit either surges or it is faulty and cannot maintain. First try finding some way to test that suspected bad circuit. If that's not it I would try replacing the power supply, that MAY NOT be your problem but it is certainly CHEAPER than replacing your processor and/or mother board. You could also have a hard drive problem; most drives have self testing features that are partitioned separate from the rest of drive. You can also try plugging your drive into a good computer and see if it boots.
I'll warn you though issues such as yours can take you down a costly road trying to trouble shoot. The components you are thinking of replacing pretty much will give you a brand new computer.
Hope this helps
Jul 31, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Compaq Presario v5000 desktop
Is there a power switch on the back of the power supply which is not on? Make sure the power cord is good and plugged into a good power source. Do the fans run inside the system? Is the fan for the power supply working? If not the power supply could be bad. You can purchase a power supply tester to plug the mother board connector into to verify the operation for about $15.00. Do you see any lights on the mother board and the Hard Drive light flickering? If you do and your Key Board lights are on your video controller or monitor could be setup wrong or defective. If the power supply tests good then you need to test the memory and CPU. You could also carefully remove all boards except the video card, mother board and memory and see if it boots up.
Mar 30, 2009 | Compaq Computers & Internet
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Help help
check ur memory card
Nov 30, 2007 | Sony Mother Board Motherboard
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
1,564 people viewed this question
Alun Cox
