Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sparks came out right rear when I pushed the power on button. Now, no power.
How expensive a repair is this? Best Buy said it is a mother board problem and the parts are not available. Seems like too good of a TV to junk. Oct 17, 2008
    Champion:
  • 252 Answers
The problem of your tv is plyback.and for me, its not too expensive than to buy a new one
Posted on Oct 18, 2008
My inspiron 1420 does not turn on.when i push the power button the light comes on then goes off. can someone tell me where i should check first?
Power supply and or battery. Take the battery out and try to start it with the ac supply only.
If you can find one try another power supply too. Sometimes when your power supply goes bad you just run the battery down till the day it wont restart.
If you have a volt meter you can read the output of the power supply and make sure it is putting out the right voltage.
Oct 14, 2010 | Dell Inspiron 1420 Laptop
Power switch doesnt turn on machine
re check the computer is plugged in, and see if u can reset the circiut breaker on the power supply, the re try tuning the computer power switch button on. if it still wont turn on then take it to a repair facility for repair and explain to them EXACTLY , How I told you this, and have them check the computer.
Nov 27, 2009 | E-Machines eMachines Desktop PC
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
Computer simply don´t open, mother board doesn´t too
TRY ANOTHER RAM IF THIS DOES NOT WORKS
TRY RESETTING THE BIOS CONFIGURATION FROM THE JUMPER ON THE MOTHERBOARD
OR ELSE THE MOTHERBOARD NEEDS A REPAIR IF IT FALLS UNDER WARRANTY PERIOD
TAKE IT TO THE SERVICE CENTER OR ELSE BUYING A NEW ONE IS THE BETTER OPTION
Jul 08, 2009 | Computers & Internet
E-Machines T2891 PC Desktop will not start when power button push
I assume that your computer doesn't start at all. If that is the case then try with another power supply. Still no result --- then mother board needs repairs or purchase a new one.
Feb 02, 2009 | E-Machines T2891 PC Desktop
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Will not power up unless I move the display back and forth
Sorry I lost my password. This is a common problem with the 610 and other laptops. This repair is not for a Novice. Please get the maintance manual from dell go to dell support its free and know the disassembly procedures for tearing your laptop apart. Remove the bezel on top of your keyboard. The start button is on a small pc board. The problem is on the connector on the bottom of this board that commects to the Mother board of your computer. Remove all external, and plug in devices to your laptop. including the battery. After removing the keyboard, the top plastic cover, the start pc board, ect. you can see the connector from the start board that connects to the mother board. Look carefully and gently see if this connector is loose. The mother board connector is supported by 2 silver looking braces on each end. gently see if they are loose. I bet that one end has broken loose from the mother board. re solder the loose end to the mother board. be careful not to damage anything as I said this is not for the novice. (with the laptop in pieces put the startup pc board back in, temporairly put the battery in and push the start button. If the led's glow, this is where the problem is. While your laptop is apart check for dust ect. You may need to remove the heat sink , and a back support brace to get to the mother board connector to re solder it.
This has been a problem on 3 of my friends laptops Pushing on a button harder and harder doesn't solve the problem. It's not the button .Now you know the rest of the story.
http://support.dell.com/edocs/system/latd610/en/sm_en/index.htm
Hopes this helps just remember where all the extra screws go when you re assemble your laptop
Dec 11, 2008 | Dell Latitude D610 Notebook
Rca 52 rear projection tv wont turn on
sounds like the small signal board issue as the replacement board is over 600.00 You can get the replacement board at the following link for a fraction of that cost. Heres the link you can leave them a email with the model number and the symptoms.
http://servicemanuals.vstore.ca/
Nov 28, 2008 | RCA D52W19 52" Rear Projection Television
Mother board problem (problem turning power on)
Try the repair service locator at the home page of Fixya. It will list any of our experts that are available or have shops in your area. I will recommend that you stay away from Bestbuy, they're expensive, and always trying ro sell you more.
Jul 13, 2008 | Dell Inspiron 600M Notebook
Rca d52w20b
Unless your a tech ....it would not be wise... the crt board as it called has very high voltages... which board was it red green or blue .. right center or left... usally when one of these boards are bad that indicates a possible problem with the actually crt.. very diffcult repair.. be carefull please
Nov 22, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
