Question about SanDisk Sansa e130 MP3 Player
Will not turn on with new battery
My battery died, so i put a new one in. After I put a new battery in, it would not turn on. Ive tryed several different new batterys from different brands, and nothin turns on.Ive had it since december 2005, and have lost the paper work. What can I do to fix it or where can I take it to get it fixed?PLEASE HELP!!!!!
Plug your SanDisk into the USB with NO Battery. After you take it out, install battery and it should work.
Posted on May 18, 2007
Alright heres what i tried. I took out the battery and pluggend it into my usb cable and apparently it turned on but when i first put it in it flashed the light once then went off so im thinking that the battery had something to do with it. Before i put it into the usb port, without the battery, i tried just taking out the battery and puting it back in later. Hope this helps.
Posted on Dec 07, 2006
Take out the battery for 5 minutes to reset it. Straight the guy at technical support that I spoke to at SanDisk.
Posted on Jun 29, 2006
    Problem Solver:
I don't think it is your battery. I had the same problem and it took me all day to solve it. I had to attach the player to my computer and reformat it. After that it worked fine.
Posted on Dec 11, 2006
  • 4 Answers
Another thing I could suggest is to check the 'Hold' switch on the bottom, if it's in the locked position you won't be able to turn it on, it'll just pop up with a message saying 'Locked' and go back off again, this message only lasts a fraction of a second but if you see it you just need to move the Hold switch the other way. (The body actually doesn't say which side is 'lock', but when it's locked there will be red instead of the normal gray behind the switch, also the 'Locked' message described above when you press a button.) This might not be your problem, but I know that a lot of people go through their player being unresponsive only to find the lock switch is set to 'locked', and that 'Locked' screen really is easy to miss, especially if you're not looking for it (which happens with a player whose buttons you know by heart). Hope this works for ya! :)
Posted on Oct 30, 2006
    Problem Solver:
I had the same problem i did as u said and it did not work i have a snsa e130 it will say usb connected when i plug it in to a computer and i can download songs to it but when i dis connect it and press the on button it wont turn on. P.S. yes i did put a brand new battery in it
Posted on Oct 17, 2006
  • 175 Answers
Well it depends where you are, are you in New Zealand? Try reseting the player if it has one other wise take it to an electronic shop to get it fix.
Posted on Jun 07, 2006
My psp 1000 wont charge or turn on, why
if you tried to hack (mode your psp) using the battery exploit i advice you to buy a new battery since ive done the same and after 2-3 week battery died .. try to turn it on without the battery in
Sep 06, 2011 | Sony PlayStation Portable (PSP) Console
Ive already put a new altinater and a brand new battery in my cutlass. it will start when i give it a jump from another car but then as soon as i try to drive it it dies on me.. and ive also cleaned the...
New battery and new alternator,you are looking for a open fusable link,If all are good you maynot be looking at a charging system, start the vehicle at idle, leave it running turn on the light and use the battery gauge on the car and turn the lights step on the brakes (vehicle in park) does it stall then, If it does then you are looking at a charging system can you exhange the battery and can you get the alternator tested from an outside source or better yet uses a voltmeter and read the charging system the battery at charging will need to be 2 volts above battery
May 29, 2011 | 1995 Oldsmobile Cutlass Ciera
Hi recieved my atomik radier250 brand new yesterday and put it all together but now after ive charged the battery i cant get the thing started ive done everytging to the poorly descriped so called manual...
If it doesn't fire right up do not keep trying you will burn up the starter Change something
1.Fuel on
2 kill switch to run
3 side stand up
4 petcock in prime position if it has one
5 Spark?
6 choke on?
7 check the spark plug to see if it smells like gas or is wet with fuel
20 seconds at a time on the starter or it will burn out
Feb 11, 2011 | Factory bike Chrono SM 250 Motorcycles
My samsung juke wont turn on. ive charged it several times and still nothing. ive sent it to electronic experts and nada. ive taken th battery in and out and nothing. Ive held the END button on the phone...
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Jun 05, 2009 | Verizon Communications Samsung Juke Cell...
Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Feb 16, 2009 | Samsung S830 Digital Camera
Ipod died
Depends how adventurous you want to be. It's most probably needs a new battery but could be a number of things. It's a matter of trail and error to work out what the error is. I would advise trying a new battery and if that doesn't work sending it or taking it to a repair center.
Oct 25, 2008 | Apple iPod MA446LL/A MP3 Player
Battery draining fast
I would check the alternator again, it apparently isn't charging the battery with engine running. You need a volt meter or amp meter to test this. Also does the battery discharge when the car is not running?
Aug 07, 2008 | 1992 Ford Tempo
Camera won't turn on with new batteries or power cord
I heard from another posting on here and the answer, that someone took fine sandpaper and cleaned off the terminal ends of both battery and camera and blew out the dust particles from that before replacing the battery, then then camera worked. I have yet to try it with my Kodak camera that is 2 years old and suddenly died too! The batteries are fine and work in other cameras.
May 07, 2008 | Kodak EasyShare C643 Digital Camera
SanDisk Sansa e130 MP3 Player Logo
760 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
