Question about Dell 922 All-In-One InkJet Printer
Help!!!! when i try to print, the mechanism that pushes the paper into the slot where it can print right, feeds it wrong. it always pushes the paper at a tilt untill it cannot go into the printer right. ive tried to fix it but nothing happens...please help me!!!!!!!!!!!
Hello, This is happening to my printer, too. Did you ever resolve this problem? Should I just chuck the printer against a wall and call it a day? Thanks, -Kathryn
Posted on Oct 27, 2006
SOURCE:
Z42 not feeding paper
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Regards,
Sanath
Feb 20, 2013 | Lexmark Color JetPrinter Z42 InkJet
Samsung ML-2580 always paper jam
Good Luck!!!!
Oct 05, 2011 | Office Equipment & Supplies
When we try to print keeps saying load paper even although there is paper in feed tray. We have tried removing and replacing apper still same problem Printer just does not seem to register that there is...
Good Luck!!!!!
Sep 24, 2011 | Lexmark X4530 InkJet Printer
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
My Epson Stylus CX6600 will not load paper into the machine.
With a flashlight, look into the throat of the paper feed mechanism. Remove any foreign material. Also, look at the edge of the paper you're trying to get it to accept. If the edge is uneven or the paper is the wrong thickness, problems arise. Located at the far left side of the paper outfeed slot, there is a lever to select between cut paper and envelopes. Position this lever to correspond to the paper you're trying to insert
Aug 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Pper jams
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Dell 922 All-In-One InkJet Printer Logo
64 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
